Author Topic: Afterburner is Haunted  (Read 948 times)
elliotdebruyn97Topic starter
« on: 24-June-15, 11:34:39 »
So I am new to Afterburner and it has great features, but they keep disappearing?  Under the monitoring tab there are only about 1/3 of the elements to track as there were right after installing.  I used to track my gpu usage, but it is no longer a thing.  I tried uninstalling then reinstalling and it worked briefly, but then things in the monitor tab disappeared again.  What's up?
I added a screenshot of what's there now, these are all of the gpu elements to track now.  There used to be a ton more, like for both gpus I could track temp, usage, memory, bus, clock speeds, and many many more than are left.
Nichrome
Re: Afterburner is Haunted
« Reply #1 on: 24-June-15, 11:40:49 »
Hi
Can you tell us what MSI hardware are you using?
https://valid.x86.fr/mbld36
« Reply #2 on: 24-June-15, 16:14:49 »
None at all.  I don't think that is pertinent though, as the elements missing were working, so it's obviously not only compatible with MSI gpus.  Unless they lock features for non MSI users after a few days when recognizing it isn't MSI hardware?  That's the only way I could see that being relevant.
darkhawk
« Reply #3 on: 24-June-15, 19:25:44 »
Well....the issue is that it is meant for MSI products. And without having an MSI GPU, we really have zero obligation to provide any support, seeing as how this is a forum for MSI hardware......
That being said, have you tried restarting MSI afterburner to see if the issue keeps happening over and over? Something just doesn't seem quite right about the situation.
System 3MSI Z390 GodlikeIntel i9 9900K32GB DDR4 @ 3600 MHz MSI RTX 2070 Gaming Z 8GB
HenryW
« Reply #4 on: 24-June-15, 21:37:18 »
 Go to this website for Afterburner issues (especially since you are not using any MSI hardware):
     http://forums.guru3d.com/
 Unwinder over there did the development work on Afterburner so you would be better off finding a solution there.
 Just scroll down the menu till you get to Afterburner section.
Z77A-GD65/BIOS 10.5, i7 2700K
W 7 Home Premium x64/SP1
Corsair TX650W
Lite-On CD/DVD combo burner
MSI 560 HAWK, Drv. 368.82
