Author Topic: MegaPC 651 & Both TV Tuner Cards  (Read 4172 times)
GiG_a_LoW
« on: 04-August-03, 15:15:52 »
Well,
  I am having a little bit of trouble here that I can't seem to figure out. I bought the Mega PC 651 with the TV@nywhere Master in hopes of having a pretty cool functioning TV card w/remote ( Last tv@nywhere didn't work). Anyhow, I got the MegaPC all put together installed all the drivers, then go to put on the MSI PVS software and I get this error:
WinDVR:
Setup failed to run installation
the remote procedure call failed.
I did everything I possibly could to get it to try and install, but it wouldn't. So I figured it was a bad CD. So I tried it with the regular TV@nywhere CD (not the MASTER version) and I got the exact same error. So I decided to swap out the tv@nywhere Master with the regular Tv@nywhere card and it did the exact same thing. Is anyone else having the same problem with this MegaPC? Please help.
msivictim
(No subject)
« Reply #1 on: 04-August-03, 20:10:55 »
The install CD is no better than the drivers. Use explorer to get to the driver folder and click on SetupDvr.exe
GiG_a_LoW
(No subject)
« Reply #2 on: 06-August-03, 11:42:50 »
I tried that and got this error:
MSI PVS Driver Installation Failed.
GiG_a_LoW
msivictim
(No subject)
« Reply #3 on: 06-August-03, 19:56:44 »
Sorry, thought it was a driver install problem.
If it's the Master, make sure the driver is from the CD (the downloadable ones, and their patches are for the original card).
Check the postings; some have had success by deleteing everything Intervideo and then re-intalling MSIPVS.
ZollyMonsta
(No subject)
« Reply #4 on: 07-August-03, 05:32:43 »
The other method is to not use MSI's driver installation method and let windows find the drivers on the cd (browse to it).  I got similar errors and the computer would reboot, using their cd to set the contraption up.
Otherwise, just ditch the card :)
Hellafax
(No subject)
« Reply #5 on: 09-September-03, 22:12:22 »
Hey Hey,
We had this issue as well -- the solution is to try unplugging the card reader or tuner (I forget which one).  For some reason, that caused a conflict, not allowing the software to install.
Hope this helps.
Matte in YHZ
