Pages: 1 [2]  All   Go Down
Author Topic: Sound Blaster Cinema 1 Potential fix on Windows 10  (Read 66830 times)
adrien.cardoso
Re: Sound Blaster Cinema 1 Potential fix on Windows 10
« Reply #50 on: 31-October-17, 13:32:20 »
God bless you! It worked on my MSI GE60 2PE!
It froze at 59%, killed setup.exe on Task Manager and now it works fine!
Thank you!!!!
dennisherold46
« Reply #51 on: 03-November-17, 09:56:55 »
No Problem 😄
aykanakduman
« Reply #52 on: 25-November-17, 09:24:50 »
wall.e0394
« Reply #53 on: 11-December-17, 18:10:46 »
It actually working. Thank you very much.:smile:
12/12/2017 with latest windows 10 updated.
harrygorder
  • CORPORAL
« Reply #54 on: 20-March-18, 08:32:13 »
FIX FOR SBC 1
Hi guys,
Thank you all for your suggestions, but nothing of your ideas fixed my SBC 1 freeze problem. I tried the compatibility mode for the setup files and the files in the installation folder, tried the CCleaner registry cleaner, updated Realtek drivers etc.
BUT I FINALLY FOUND A FIX that is working for me.
Just download and install Sound Blaster Cinema 2 without uninstalling SBC 1!   Download link: http://download.msi.com/uti_exe/sbc_2.zip
Before you run the setup, close SBC 1 in the Task Manager.
If the SBC 2 setup stucks at 59% or does not fully install, just close the setup.exe task or process in the Task Manager.
The Sound Blaster Cinema 1 should work now and should not freeze anymore. If not, try to delete the SBCinema.exe.config file in the SBC 1 folder. :)
Hope this works for you too! :)
Tested on a MSI GE70 2PE Apache Pro Notebook with Windows 10 64 Bit, Version 1703 (Creators Update)
 Worked also in my Z97-G45 Gaming.
Shame NO oficial updated version or fix come to us because this is a little bit bungler and make me think 2 times buy another MSI motherboard again, but, well, thanks.
Rhadamanthis82
  • Rhadamanthis
« Reply #55 on: 21-March-18, 14:36:08 »
Hi, with drivers audio realteak is compatible windows 10 with sound blaster cinema 1?
Kitsunefoxie
« Reply #56 on: 05-April-18, 20:15:37 »
I've a 970 gaming motherboard. What's the latest version of the SBC 1 software?
The SBC2 is all the way back from 2015.
What's the latest version of that too?
Windows 10 Enterprise
Motherboard
OctalCore AMD FX-8320, 3700 MHz (18.5 x 200)
MSI 970 Gaming
RAM 16GB
G Skill Ares F3-2133C11-4GAO 4 GB DDR3-1600
G Skill RipjawsX F3-12800CL9-4GBXL 4 GB DDR3-1600
Display
Gigabyte Radeon HD 7950 3GB
Multimedia
Asus Xonar DG Sound Card
Storage
Samsung SSD 850 EVO 250GB  (250 GB, SATA-III)
TOSHIBA HDWD110  (1 TB, 7200 RPM, SATA-III)
SAMSUNG HD103SI  (1 TB, 5400 RPM, SATA-II)
PSU
Be Quiet! 600W Pure Power 55A 12v
santathe1
  • CORPORAL
« Reply #57 on: 17-May-18, 12:09:04 »
Thank you so much. Confirmed, this is working on a GT60 2OC-22US :)
It didn't work for me initially, but it seems I didn't have the Realtek Drivers (that are available on my Laptop's product page) installed. I installed that and voila, working SBC1.
Steps I followed:
1. Installed SBC1.
2. Rebooted
3. Installed SBC2 (got stuck at 59%) (Disabled SBC2 and Creative Updreg in task manager startup, removed the .config file in SBC1 folder).
4. Rebooted
5. Installed Realtek Drivers.
6. Rebooted
7. Working SBC1
Machine : MSi GT60 2OC-022US
CPU : Intel® Core™ i7-4700MQ
GPU : NVIDIA® GeForce® GTX 770M 3G GDDR5
Memory : 16GB DDR3L 1600MHz
Disk : 2TB
OS : Windows 10
mahyar.ghazinour
« Reply #58 on: 05-December-18, 19:18:42 »
Thanks a lot.
veganfanatic
  • SECOND LIEUTENANT
    • HARDCORE GAMES™
« Reply #59 on: 27-June-19, 21:29:14 »
I install every new version of Windows clean mostly to get around problems.
Legacy devices can be a nuisance depending on the machine but Windows 10 acan accept Windows 7 and 8 drivers when no Windows 10 drivers are available.
I suggest collecting drivers and save to a USB stick or burn them to a CD/DVD/BD for for reinstall
Cooler Master HAF 932 powered by the Corsair HX1000i PSU
  • 微星科技
« Reply #60 on: 28-June-19, 11:52:32 »
The thread is a year old. Don't resurrect old threads.
:floblock:
AMD Ryzen 9 3900X
Windows 10 Pro
Pages: 1 [2]  All   Go Up
