Author Topic: Workstation Wallpaper  (Read 1334 times)
cruzTopic starter
« on: 27-September-15, 09:29:38 »
Hello there!
I just bought the WT72 2OK and would like to use the Workstation Wallpaper that I often see out there. Where can I find it? Cant see it in the wallpapers section of the MSI site...
Thanks for your attention!
HenryW
Re: Workstation Wallpaper
« Reply #1 on: 27-September-15, 20:52:28 »
Good luck, MSI is so focused on gaming that it seems like that is the only kind of stuff you can find anymore.
 Can you post any pictures of the wallpaper you are referring to?
Z77A-GD65/BIOS 10.5, i7 2700K
W 7 Home Premium x64/SP1
Corsair TX650W
Lite-On CD/DVD combo burner
MSI 560 HAWK, Drv. 368.82
cruzTopic starter
« Reply #2 on: 28-September-15, 10:55:30 »
Hello HenryW!
Thank you for your kind reply!
Im looking for this one that is attached in this post. As we can see in the image, its just the simple black with the workstation logo and the green text...
D.L.
  • FIRST LIEUTENANT
« Reply #3 on: 30-September-15, 01:43:33 »
Here you go! The attachment should be the wallpaper you want.
cruzTopic starter
« Reply #4 on: 30-September-15, 04:26:43 »
Thats the one! Thanks a lot D.L.!
Dont know why is not available on the MSI wallpapers page...
