Author Topic: MSI B150M Night Elf CPU Support  (Read 1293 times)
urcprolamaTopic starter
« on: 03-November-15, 11:55:13 »
Hello Friends,
Is there anyone who know that the G4400 CPU is it supported by this motherboard (B150M Night Elf).
This answer is important for me bacause I would like to one from this.
Thank you for your help.
Nichrome
Re: MSI B150M Night Elf CPU Support
« Reply #1 on: 03-November-15, 12:10:53 »
Hi
I believe it is not on the compatibility list yet because it was released later than other Skylake CPUs. But should work fine.
Chike
  • GENERAL
« Reply #2 on: 03-November-15, 12:12:44 »
You can ask MSI >>How to contact MSI<<
CPU: i5-4670k
Cooler: CNPS10x Performa
Memory: F3-2400C11D-16GXM
HDD: WDC WD3200AAKS-00L9A0
PSU: Antec 500W VP500PC
Case: Compucase 6C60
HenryW
« Reply #3 on: 03-November-15, 12:54:14 »
G4400T is on the list and specs for it and G4400 are identical except for speed and TDP. TDP for the G4400 would be higher due to higher clock speed.
 I agree with NiCr that it should work just fine due to same specs as G4400T.
Z77A-GD65/BIOS 10.5, i7 2700K
W 7 Home Premium x64/SP1
Corsair TX650W
Lite-On CD/DVD combo burner
MSI 560 HAWK, Drv. 368.82
