Author Topic: Win10 Pro upgrade from Win7 Pro  (Read 2263 times)
This topic contains a post which is marked as Best Answer. Press here if you would like to see it.
.MadCat.Topic starter
  • STAFF SERGEANT
« on: 13-November-15, 02:37:38 »
Hi
I'm going to build up my PC
Is there any issues with these msi bits with the Win10 upgrade
MSI Z170A-Gaming Pro Motherboard
Intel Core i5 6500
Corsair Vengeance LPX CMK16GX4M4A2133C13 16GB (4x4GB) DDR4
MSI GeForce GTX 960 Gaming 4GB
Windows 10
MSI Z170A Gaming Pro
Intel i5 6600K
MSI GeForce GTX 960 Gaming 4Gb
Corsair H110i GTX CPU Cooler
Corsair Vengeance LPX 16Gb Ram
Corsair HX1200i 80+ Platinum PSU
Corsaie 750D Case
Western Digital 1Tb Black HDD
  • T9246ED
  • Administrator
Re: Win10 Pro upgrade from Win7 Pro
« Reply #1 on: 19-November-15, 07:32:08 »
I see no issues.
Else you can check more detailed list about memory QVL here:
http://www.msi.com/product/motherboard/support/Z170A-GAMING-PRO.html#support-mem
http://www.msi.com/product/motherboard/support/Z170A-GAMING-PRO.html#support-ocmem
But what PSU you are planning to use?
Nichrome
« Reply #2 on: 19-November-15, 07:39:24 »
All looks fine for me too.
As for PSU, please make sure to get a good quality one, else you might regret buying this build if you get a cheap PSU.
tmursch
  • SECOND LIEUTENANT
« Reply #3 on: 19-November-15, 07:57:10 »
Do you have a specific need for Windows 10?
CPU: Intel(R) Core™ i7-6700K 4.00 GHz
MOTHERBOARD: MSI Z170A Krait Gaming
COOLER: Noctua NH-D9L Dual Tower CPU Cooler
RAMG.SKILL Ripjaws 4 Series 32GB (4 x 8GB) DDR4 2800
HDD: 512GB SanDisk X300 SATA III SSD
HDD2: 2TB Toshiba SATA III HDD
HDD3: 500GB SAMSUNG 850 EVO M.2 500GB SATA III SSD
OS: Windows 7 Ultimate x64 SP1 (G
enuine licensed copy)
POWER: EVGA SuperNOVA 1050 Watt Power Supply
VIDEO: EVGA GeForce GTX 980 Ti 06G-P4-4995-KR 6GB SC+
MONITOR: ASUS VG248QE - 144Hz Refresh Rate
hansmooiman1963
  • SECOND LIEUTENANT
« Reply #4 on: 19-November-15, 10:57:20 »
I have tried Window 10 for several weeks and I think windows 8.1 is fare more stable  everything is working  flawless.
Windows 10 looks too be working fine but then suddenly BSOD while gaming  it is jut not as stable as window 8.1 .
  • STAFF SERGEANT
« Reply #5 on: 19-November-15, 20:13:58 »
I'm going to go with the Intel Core i5 6600K insead for the overclocking capabilities
PSU going with Corsair HX850i 850W 80 Plus Platinum Power Supply
I've got Win7 Pro (have to rip it out of a pc) but thort Win10 Pro upgrade would  be ok as long as there's know issues with MSI and Win10
Windows 10
Intel i5 6600K
Corsaie 750D Case
Marked as best answer by .MadCat. on 20-November-15, 11:22:24
Nichrome
« Reply #6 on: 20-November-15, 01:33:04 »
Good PSU.
As for OS, it is up to you. Next Battlefield release will require DX12 if you would like to play on Max settings. And next release after this one, DX12 will be minimum. And DX12 is only available on Win10...
  • STAFF SERGEANT
« Reply #7 on: 20-November-15, 03:21:33 »
Well that makes it worth the upgrade
Once i get the OS out of the temp pc and build the new one
Upgrade it is!
Windows 10
Intel i5 6600K
Corsaie 750D Case
  • STAFF SERGEANT
« Reply #8 on: 20-November-15, 03:23:30 »
Thanks for all your help
Windows 10
Intel i5 6600K
Corsaie 750D Case
