Author Topic: Afterburner OSD  (Read 1181 times)
jonnrod66Topic starter
Afterburner OSD
« on: 14-November-15, 13:08:00 »
New to afterburner need a little advice, I have read "how to use afterburner and followed the instructions on configuring OSD. The info shows on screen in Kombuster but cannot get the afterburner info to show in either TitanFall or Left for dead on screen.  Even using hot button keys will not do it.  Don't know what I'm doing wrong.
Thanks for your help.
Antec Darkfleet case
MSI Big Bang X-power mobo
New MSI  960 4gb gaming
12 gb corsair mem
Intel I7 960 3.2ghz
Marked as best answer by jonnrod66 on 14-November-15, 15:10:51
  • 微星科技
Re: Afterburner OSD
« Reply #1 on: 14-November-15, 14:10:14 »
It might be blocked in these online games. Check with offline games.
Windows 10 Pro
MSI MAG BUNKER Case
Re: Afterburner OSD
« Reply #2 on: 14-November-15, 15:11:57 »
Thank you for your answer
darkhawk
Re: Afterburner OSD
« Reply #3 on: 15-November-15, 13:44:19 »
I've always had issues getting the OSD to display on any steam games due to the steam overlay.
System 3MSI Z390 GodlikeIntel i9 9900K32GB DDR4 @ 3600 MHz MSI RTX 2070 Gaming Z 8GB
Re: Afterburner OSD
« Reply #4 on: 15-November-15, 14:57:36 »
Thanks for the reply darkhawk
