Author Topic: Issue with Time and Date, dead battery resets Time and Date.  (Read 1681 times)
eschristopherTopic starter
I am having issue with my Primo 81, when the battery dies, the time and date resets to 1970....I am not sure if this is a OS issue.  it is running 4.2.2 Andriod, I would like to update it to 4.4, but not sure how...
I use it sparingly, mainly just for reading, so I will not use for months at a time and then use it for a month or more to read a book.
Any assistance on this would be appreciate.
D.L.
  • FIRST LIEUTENANT
Re: Issue with Time and Date, dead battery resets Time and Date.
« Reply #1 on: 17-November-15, 21:59:53 »
What do you mean the battery is dead?
If the battery is dead, you should seek support from the original store of purchase or distributor to change the battery, since it's normal that time will reset when battery stops supply power.
