Author Topic: BIOS in MSI w20 3m  (Read 1902 times)
nezionTopic starter
BIOS in MSI w20 3m
« on: 04-December-15, 23:37:44 »
Windows has lost data in BCD file. I have read in Internet that I should boot from USB with Windows Installation. But my tablet didn't boot from it. I have selected "Legacy" in boot method. But now it doesn't boot from anywhere. How can I change boot method or reset BIOS setting?
darkhawk
Re: BIOS in MSI w20 3m
« Reply #1 on: 05-December-15, 06:52:29 »
If you have the tablet connected to the AC adapter and plug in a USB keyboard, can you access the BIOS by using the keyboard? By pressing F2, DEL, or maybe F10? What about if you hit F12 to bring up the boot menu with the USB stick you want to boot from plugged in?
nezionTopic starter
« Reply #2 on: 05-December-15, 07:30:35 »
It is main trouble. I can't access BIOS, even I press that keys. He just replys me "Reboot and select proper boot device or Insert Boot media in selected boot device and press a key..."
solimar.545
« Reply #3 on: 19-August-19, 10:35:26 »
