Author Topic: Want to run RAID1  (Read 1798 times)
.MadCat.Topic starter
  • STAFF SERGEANT
Want to run RAID1
« on: 13-December-15, 22:09:29 »
Hi
I've just set up my PC and got a spear HDD
I'm thinking of setting up RAID1
What I want to know is, if I get into the BIOS and set the drives to RAID1 will I need to reinstall everything on my PC?
Windows 10
MSI Z170A Gaming Pro
Intel i5 6600K
MSI GeForce GTX 960 Gaming 4Gb
Corsair H110i GTX CPU Cooler
Corsair Vengeance LPX 16Gb Ram
Corsair HX1200i 80+ Platinum PSU
Corsaie 750D Case
Western Digital 1Tb Black HDD
Marked as best answer by .MadCat. on 14-December-15, 13:46:51
Nichrome
Re: Want to run RAID1
« Reply #1 on: 14-December-15, 00:40:13 »
Hi
Yes you will need to reinstall things.
You set drives to RAID mode.
Press Ctrl  and (C I believe) and set up an array. But it slows the boot a bit down, as Intel RAID has to start before system POSTs.
  • STAFF SERGEANT
« Reply #2 on: 14-December-15, 02:18:05 »
That's cool
I'll get the software protection
That's the main thing
Windows 10
Intel i5 6600K
Corsaie 750D Case
  • STAFF SERGEANT
« Reply #3 on: 15-December-15, 19:05:56 »
Hi
Can't get into the IRST Option ROM
Ctrl+i or Ctrl+c i is not working
Any ideas?
Windows 10
Intel i5 6600K
Corsaie 750D Case
Nichrome
« Reply #4 on: 16-December-15, 03:26:10 »
Hi
Try basic PS/2 keyboard.
Also update your BIOS.
  • STAFF SERGEANT
« Reply #5 on: 16-December-15, 05:09:37 »
Humm
Don't have a PS/2 keyboard
If i uninstall everything
Is there a way of setting the raid up before an install of win10?
Windows 10
Intel i5 6600K
Corsaie 750D Case
Nichrome
« Reply #6 on: 16-December-15, 13:33:58 »
That's what you have to do. Enable RAID in BIOS. During boot it will show you Intel's ROM and what keys to press. Then setup the array (add drives) and then install Windows to that array.
