Author Topic: 【MSI PRO MOD - S3 】Project HEX v2  (Read 3127 times)
jjsky5000Topic starter
  • CORPORAL
« on: 29-December-15, 20:07:36 »
Thank you MSI  for hosting another Awesome  Modding Competition
The Theme is to Make The Z97S SLI Krait Edition Stand out on my Free standing hexagon Case design,  The case is made only using hand tools
Components
MSI Z97S SLi Krait Edition MB
MSI R9 390 Gaming 8G GPU
HYPERX Fury DDR3 8 GB
2 HYPERX Fury 240 SSD
EVGA 850 NOVA PS
2 Thermaltake Pacific P1 Black D5
2 Thermaltake Pacific R360 Radiator
Thermaltake Pacific W1 CPU Water Block
12 Enermax Vegas Fans
  • CORPORAL
Re: 【MSI PRO MOD - S3 】Project HEX v2
« Reply #1 on: 29-December-15, 20:19:14 »
After positioning The fans , MB and SSD location Me and My friend Haley Began to Layout over 100 hexagons
Next Up cutting out the Main Base support 3/8 Acrylic   And the Fan holes
Using a jig saw, Hole drill and Dremal,  Cut out all the Opening for wiring, vans and lights
Next up adding a Solid Base
  • CORPORAL
« Reply #2 on: 30-December-15, 21:26:56 »
Attaching RADs and fans and organizing  The fan Cables
Up Next Installing our Thermaltake CPU Block and Hyperx Fury Ram
Installing The FuryX Ram
Installing The MSI Z97S SLI Krait edition MB
Attached the ATX Power
Prepared our PETG Tubing for Watringcooling
looks good but did leak and had to redo ,  during the test run
  • CORPORAL
« Reply #3 on: 30-December-15, 21:42:21 »
GPU Fan and Shroud has finished drying and prepping to add the new Viynal
Testing the Fans
Making the NEW front logo/gpu Stand weld on #14
actually had to redo this stand about 3 times
Just in time a New package
a new GPU extension from Thermaltake,  I have tried 4 others ones hope this one works
Fits perfect
My hand made rez has seen better days and finishing the loop
I think its ready to test Fire
  • CORPORAL
« Reply #4 on: 30-December-15, 21:52:50 »
Final preparations
First time using my new Background , should have went horizontally
Final Pics
  • CORPORAL
« Reply #5 on: 07-January-16, 09:51:20 »
Showing the HEX v2 lighting Function
