Author Topic: Z170 Gaming M5 Power Options problem  (Read 940 times)
007serkanTopic starter
« on: 20-January-16, 06:26:54 »
Hi Users
my problem starting command center update 2.0.0.21
MB Bios : 1.6
OSX : win x64 1511
CPU : 6700K
VGA : 780TI SC
Windows Power saver options not work correctly cpu speed always max,can't underclok,voltage
Bios options "eist,c-state" enable or disable not effective
BR
skywalker
Re: Z170 Gaming M5 Power Options problem
« Reply #1 on: 20-January-16, 22:52:53 »
Did you check your bios?
it seems like that you turn on the "Game boost".
Turn off it, and CPU speed would be automatically adjusted.
  • T9246ED
  • Administrator
« Reply #2 on: 21-January-16, 11:54:52 »
check which power profile from control panel you are using, and switch to balanced
