Author Topic: MAC Address showing as 88 88 88 88 87 88  (Read 11508 times)
ideneTopic starter
« on: 25-January-16, 03:27:22 »
Hi Everyone
I have a problem where my Mac address is showing as: 88 88 88 88 87 88 and my GUID is: FFFFFFF FF FFFFF FFFFFFF FFFF (all F's basically).
How can I reset the motherboard?
I have tried resetting the CMOS/flashing the BIOS etc but nothing has changed those 2 numbers..
My model of Motherboard is X79A-GD45
  • 微星科技
Re: MAC Address showing as 88 88 88 88 87 88
« Reply #1 on: 25-January-16, 05:38:04 »
I guess you tried to flash your board with fpt and did not use -savemac option. Anyway MAC is deleted. Restore it with the guide below that has been created by MSI Support USA. It is down somehow so i pasted the google cache. Use the attached EEUPDATE.exe.
If your MAC address is not showing up correctly, please follow the steps below:
1.   You will need to create a DOS bootable USB flash drive. Download and save both of the following to your desktop. Also, extract Win98SE_bootdisk.zip to your desktop.
Download usb_format.exe here.
Download Win98SE_bootdisk here.
2. Run usb_format.exe. Select your flash drive, FAT32, Quick Format, and Create a DOS Bootable Disk. Browse the path where you extracted the Win98SE_bootdisk files. Click Start.
3. Your DOS bootable drive is now created. Copy Eeupdate.exe to your flash drive. Download Eeupdate.exe here.
[/color]
4. Locate the 12-character MAC address for your motherboard. This can be found on a sticker on top of the LAN port. Write this down.
[/color]
5. Set your flash drive as the first boot device or press F11 during bootup to manually boot from it.
6. At the command prompt, type: "eeupdate /nic=1 /mac=xxxxxxxxxxxx"
Note: xxxxxxxxxxxx = the MAC address you wrote down earlier.
7. You should see the following screen. The MAC address has been successfully updated.
[/color]
8. To verify that the MAC address has been updated, type: "eeupdate /nic=1 /mac_dump"
[/color]
AMD Ryzen 9 3900X
Windows 10 Pro
ideneTopic starter
« Reply #2 on: 25-January-16, 05:39:38 »
Amazing.
Thank you so much.
Will this also resolve the issue with the GUID being all FFFFF's?
  • 微星科技
« Reply #3 on: 25-January-16, 05:40:17 »
Should
AMD Ryzen 9 3900X
Windows 10 Pro
larsdebr
« Reply #4 on: 25-January-16, 05:42:41 »
Tnx men
ideneTopic starter
« Reply #5 on: 08-March-16, 06:19:22 »
Should
I ran the method you showed and got the MAC address back but the GUID remained as F's...
  • 微星科技
« Reply #6 on: 08-March-16, 10:43:13 »
Where do you see that?
AMD Ryzen 9 3900X
Windows 10 Pro
