Author Topic: MSI B85-G43 GAMING : POSSIBLE TO OVERCLOCK  (Read 3625 times)
rbankodesignTopic starter
« on: 19-February-16, 03:45:00 »
As the title says - Is it possible to overclock my i5 4690k on this motherboard?
  • 微星科技
Re: MSI B85-G43 GAMING : POSSIBLE TO OVERCLOCK
« Reply #1 on: 19-February-16, 08:43:17 »
No, you can't use core ratio oc with Haswell i5 or i7 K cpus on on any board not using a Z87 or Z97 chipset board. You might only be able to increase BCLK to about 103Mhz but that wouldn't justify buying an unlocked cpu.
MSI X299 Gaming M7 ACK (MS-7A90) Bios 1.A0
Windows 10 Pro
MSI MAG BUNKER Case
Chike
  • MAJOR GENERAL
« Reply #2 on: 19-February-16, 09:48:10 »
https://forum-en.msi.com/index.php?topic=265945.0
CPU: i5-4670k
Cooler: CNPS10x Performa
Memory: F3-2400C11D-16GXM
SSD: 1. Samsung PM981 512GB, 2.  Samsung 840 EVO 120GB
HDD: WDC WD3200AAKS-00L9A0
PSU: Antec 500W VP500PC
Case: Compucase 6C60
« Reply #3 on: 19-February-16, 14:34:46 »
There seems to be a lot of conficting information on weather its possible to OC this motherboard.
Can anyone share or know which bios version is unlocked?
  • 微星科技
« Reply #4 on: 20-February-16, 04:21:28 »
It is NOT officially supported for oc. Many users that have been mislead by reports on the internet complained about lacking oc abilities. I don't know how these particular cases are set up but neither Intel allows oc on non-Z boards (except for Pentium Anniversary Edition) nor MSI confirms breaking Intel rules. In the past MSi always went by Intel rules.
Windows 10 Pro
MSI MAG BUNKER Case
