Author Topic: Black screen after update bios  (Read 5085 times)
lopez55Topic starter
« on: 21-April-16, 07:47:15 »
I was updating bios and appears black screen . the fans are working . I take out the batteries and reset the CMOS but it still does not work. Can You help me ?
MSI Z170A GAMING PRO
  • T9246ED
  • Administrator
Re: Black screen after update bios
« Reply #1 on: 21-April-16, 07:50:18 »
does bios update completed successfully?
how did you flashed your bios?
« Reply #2 on: 21-April-16, 07:59:31 »
I left the room during the update when I got was a black screen . I was updating the system level
  • T9246ED
  • Administrator
« Reply #3 on: 21-April-16, 08:00:32 »
system level means?
when you >>Clear CMOS Guide<< the cmos have you removed power cord from the PSU 1st?
what debug led shows or EZ debug when you try to boot now?
« Reply #4 on: 21-April-16, 08:04:55 »
reset the CMOS , does not show any errors
nlomovoy
« Reply #5 on: 21-April-16, 08:43:34 »
I had exact same problem, just with different motherboard. I have MSI 970 Gaming AM3+ board. I tried every method available over the Internet, but nothing help - CMOS reset, put bios on usb drive and try to boot with Ctrl+Home thing, everything.
Had to send my mobo to service centre, took them 2 weeks including shipping time to flash my mobo bios.
My initial issue was with motherboard RAM slots being too tight from the start and RAM didn't go completely inside for something less than a millimetre - something you cannot notice with your eye. So I put the RAM in usual way just gently press until it snaps into slots, but that was not enough. After several minutes of operation it was simply causing RAM issues and black screen - that is what happened during my BIOS update and much likely happened to you. Even after service centre I got black screen again and was like 'what the hell' - then I've connected my PC-speaker and got beeping which means RAM failure on AMI BIOS. So I have fixed it just by applying more pressure on my RAM sticks - literally push it hard inside with both thumbs. After that I don't have any issues with my mobo.
Hope this might give you an idea what to check and maybe RAM slots are causing issues in your case as well.
« Reply #6 on: 21-April-16, 09:33:39 »
stick with the BIOS , ctrl + home, I do NOT insert the end of memory?
nlomovoy
  • T9246ED
  • Administrator
« Reply #8 on: 21-April-16, 12:00:04 »
you still don't answer what EZ Debug shows?
can you also list full system specs, see >>Posting Guide<<
« Reply #9 on: 21-April-16, 12:28:00 »
Where is the EZ DEBUG ?
Main Board: MSI Z170A GAMING PRO________________
Bios Version: I DONT KNOW S/N __601 7984 010B1509002244______________________________
Video Card:
Sapphire R9 390 NITRO, 8GB GDDR5, 512 Bit, HDMI, DVI, 3xDP, Box
PSU brand and model:
SilentiumPC Enduro FM1 Gold, 550W, Modular
12v rail Rating of listed PSU_______________________________________
CPU
 Intel Core i5-6600K, 3.5GHz, 6MB, BOX
Memory____
G.Skill Ripjaws V DDR4, 2x8GB, 3000MHz, CL15 (F4-3000C15D-16GVRB)
SSD/ HDD_________
SSD Transcend SSD370 128GB SATA3
CPU COOLER_
CPU SilentiumPC Fortis 3 HE1425
Raid Card_______________________________________
Sound Card_______________________________________
Keyboard: _______________________________________
Mouse: a4tech bloody m9_______________________________________
Any Additional hardware plugged into your system_______________________________________
OC: (Yes / No)  NO
Operating System: WINDOWS 7 ULTIMATE X64___________________________________
  • T9246ED
  • Administrator
« Reply #10 on: 21-April-16, 13:11:18 »
check it in your mainboard manual
also try to boot with 1 memory stick only
« Reply #11 on: 21-April-16, 14:03:56 »
no change
  • T9246ED
  • Administrator
« Reply #12 on: 22-April-16, 03:10:17 »
3rd time:
EZ Debug??
no change
try remove your Sapphire R9 390 NITRO
and boot with intergrated one instead
aras1599
« Reply #13 on: 22-April-16, 03:59:07 »
debug shows cpu , BUT ALREADY earlier showed how computer work. What if the computer starts running drive dvd / cd can upload bios on the board ?
only needs instructions
  • T9246ED
  • Administrator
« Reply #14 on: 22-April-16, 04:03:07 »
in a case that you have a bad flash,[say the flash process was interupted]
you can place your old BIOS file[before the update attempt, you can download it from MSI web page]
and then to follow those instructions to recover it:
https://service.msicomputer.com/msi_user/support/techfaqdetail.aspx?formid=3046
we don't know if you have a bad flash or not, since you didn't watched the flashing process.
if this doesn't helps, then you have to swap a parts if you have, like CPU /memory,
else to RMA the board.
aras1599
« Reply #15 on: 22-April-16, 04:10:10 »
Components are efficient because they work before updating the bios . I have uploaded the file on the flash drive but still a black screen.
  • T9246ED
  • Administrator
« Reply #16 on: 22-April-16, 04:11:58 »
Yes i know, but that's not my point.
My point is that the new BIOS don't like some of them, therefor you end to this issue.
swap parts if you have or RMA the board
aras1599
« Reply #17 on: 22-April-16, 04:24:46 »
I have no other RAM . I turned on without ram a black image
