Author Topic: MSI g43 z170 plus Audio Problem  (Read 4041 times)
pinsala21Topic starter
« on: 05-May-16, 01:38:23 »
HI guys!
Hope someone can help me to fix this problem
Specs:
Monitor: LG 23mp67 (Dsub-HDMI)
MSI Z170a g43 PLUS
GSKILL 8gb ddr4 2400mhz
i5 6600k
Asus DQ II 7970
1TB SG HDD
500GB SG HDD
Intel 320 240gb SSD
Corsair GS800 PSU
My problem is that i do not have audio on front panel and at the back panel of the motherboard itself.
I already try to uninstall drivers on device manager
Reformat/Clean boot
Still the same problem,
And whenever I check the device manager, this is what I see
High definition Audio Controller
This device cannot start. (Code 10)
{Operation Failed}
The requested operation was unsuccessful.
Here's the catch!
Sometimes Realtek Audio Manager randomly shows whenever I reboot my PC.
Then after a day again there is no sound.
I can only hear sound when I plugged my headset on the audio port of my monitor itself.
I do hope someone can enlighten me regarding this.
Is it driver conflict or Motherboard issue?
Thanks!
xmad
  • Salisbury MD
Re: MSI g43 z170 plus Audio Problem
« Reply #1 on: 05-May-16, 06:54:16 »
If you click on the device, what does it say is wrong? (In device Manager)
IE: Code 10....   No driver ..
Any hardware or software changes when this started?
Try clearing the cmos?
Mainboard: X79A-GD65 (8D)
CPU: I7-3930K
Setting: 2400 CL:10
SSD: Corsair GS 256GB
Corsair Link
Cooling: Corsair H100I
  • T9246ED
  • Administrator
« Reply #2 on: 05-May-16, 13:35:06 »
bump removed, >>Please read and comply with the Forum Rules.<<
about clear cmos see here: >>Clear CMOS Guide<<
tell also what bios version you are using
and what audio driver version?
« Reply #3 on: 05-May-16, 19:10:37 »
Update:
I already clear CMOS still the same results
Bios: Version AMI 3.5
Audi driver used: 6.0.1.7730
What do you think guys?
Is it driver issue or motherboard issue?
Really need your help.
plutomate
  • MAJOR GENERAL
« Reply #4 on: 05-May-16, 21:10:05 »
There is usally a "Sound, video and game controllers" tab under software devices in device manager, i don't see it in ur picture tho. :think:
« Reply #5 on: 05-May-16, 23:18:12 »
Steps taken
Format again windows 10
Cables used: DVI to VGA and DVI to HDMI
=Same results
Format w/ Windows 7
=Same results
Is this mobo or driver issue?
« Reply #6 on: 05-May-16, 23:19:08 »
Another PIC
plutomate
  • MAJOR GENERAL
« Reply #7 on: 06-May-16, 01:10:23 »
if i were you, i would probably make sure the BIOS is up to date. (what is ur current BIOS version??) and take the  board out of the case and place on a wood board to avoid anything shorten in the case
xmad
  • Salisbury MD
« Reply #8 on: 06-May-16, 06:09:58 »
Code 10 on the device.
Try removing the mainboard and check under the board for extra stand off's or other shorts.
CPU: I7-3930K
Setting: 2400 CL:10
Corsair Link
  • T9246ED
  • Administrator
« Reply #9 on: 06-May-16, 07:47:15 »
about bios its already latest version 3.5
yeah like other says try with board out of PC case
is your windows up to date from windows update?
do you use the latest release of windows version?
can you test the sound card under a different OS?
« Reply #10 on: 07-May-16, 07:15:45 »
My bios is up to date and I already try OS such as 7/8.1/10
Still the same issue.
I will try to remove the board on my case and I will check what will happen.
« Reply #11 on: 12-May-16, 08:55:40 »
Update:
I already try the suggestion to boot my mobo out in the case.
After i boot up the realtek is recognized in Device Manager.
But once i restarted it again the realtek disappears.
But here's what i noticed.
Everytime i reset CMOS realtek is recognized in my Device Manager.
But after i shutdown/restart again realtek disappears.
Is it driver or motherboard issue?
Im so lost.
I hope someone can help me.
Thanks.
xmad
  • Salisbury MD
« Reply #12 on: 12-May-16, 09:00:31 »
Main board
I would RMA it or disable the device and install a Sound Blaster or something like that.
CPU: I7-3930K
Setting: 2400 CL:10
Corsair Link
« Reply #13 on: 15-May-16, 02:36:01 »
Quick update.
Here's what I notice also.
Whenever XMP profile is ON I dont have sound.
But once I deactivate it.
There is sound, and my realtek driver is recognized by my PC.
Is this a bug?
Should i still RMA my motherboard?
Thanks!
  • T9246ED
  • Administrator
« Reply #14 on: 15-May-16, 09:33:26 »
sounds like a bios bug
try .360 BIOS below
« Reply #15 on: 15-May-16, 19:36:46 »
^ Sir, is that the latest version of the bios for my motherboard?
And how can i flash this kind of bios?
Shall i just copy it to my usb and go to bios and update it?
Thanks.
  • T9246ED
  • Administrator
« Reply #16 on: 16-May-16, 08:34:26 »
yes, use M-Flash to flash it
« Reply #17 on: 16-May-16, 10:42:10 »
Update: I already updated the bios and activated the XMP.
But same results no sound.
So i just reset the CMOS and Whoala! Realtek is recognized again.
So i think there is a conflict when I activate the XMP.
  • T9246ED
  • Administrator
« Reply #18 on: 16-May-16, 10:47:20 »
oki, report the issue to msi here:
>>How to contact MSI.<<
