Author Topic: [MSI PRO MOD – S4] Radioactivo 2  (Read 5618 times)
tantricmodzTopic starter
  • SECOND LIEUTENANT
« on: 25-May-16, 01:16:28 »
Hello MSI Modding Fan's
I'm back again, with this year's MSI Promod Season 4. Before I present my project. I would like to thank MSI Global, Intel and Corsair
for making this event possible. It's always a great honor to be part of this awesome event.
thanks! and goodluck to all the other participants :D
  • SECOND LIEUTENANT
Re: [MSI PRO MOD – S4] radioactivo 2
« Reply #1 on: 25-May-16, 05:22:03 »
snapped some quick photos of the parts that will be used on this project.
Corsair Carbide 600C
more goodies from Corsair
edwindecatalina24
  • SERGEANT
  • ED MOR CRAFT
Re: [MSI PRO MOD – S4] Radioactivo 2
« Reply #2 on: 15-June-16, 02:54:44 »
:agrees: :agrees: :agrees:
MSI-MKT
  • MSI Tech
  • MSI Marketing
« Reply #3 on: 11-July-16, 18:59:45 »
Thanks for your participation!
MSI PRO MOD S4 will end on JUL 17, 2016 11:59 PM (GMT +8)
Soft remind as below:
1. Please finish the mod and update the FINAL worklog with at least 5 pictures of your FINAL mod.
2. HAVE to reply the following message under the campaign thread (https://forum-en.msi.com/index.php?topic=270503.0by JUL 17, 2016 11:59 PM (GMT +8).
  • MOD entry title
  • URL of your worklog
thanks~
  • SECOND LIEUTENANT
« Reply #4 on: 12-July-16, 18:57:33 »
sorry for the lack of updates. after the long wait, the motherboard, gpu and processor arrived time to post some updates.
the stock gpu cooler will be removed and replaced by this.
Intel core i5 6700k
  • SECOND LIEUTENANT
« Reply #5 on: 12-July-16, 19:01:13 »
i've dismantled the corsair cooler and will reuse the radiator for the custom watercooling loop.
doing a quick test fit
  • SECOND LIEUTENANT
« Reply #6 on: 12-July-16, 19:07:16 »
After taking all the measurements I needed for the case. I draw a quick layout of all the parts that will need to be lasercut.
  • SECOND LIEUTENANT
« Reply #7 on: 12-July-16, 19:11:44 »
first up. the custom backplate for the gpu.
with the gpu block.
also a quick preview on the side panels.
  • SECOND LIEUTENANT
« Reply #8 on: 12-July-16, 19:13:21 »
testing also the custom cables sleeves. just finished making this one.  I'm loving the color  :D
  • SECOND LIEUTENANT
« Reply #9 on: 12-July-16, 19:14:56 »
also started laying out the tubing for the custom LCS loop.
  • SECOND LIEUTENANT
« Reply #10 on: 12-July-16, 19:17:32 »
some more pics and final layout of the tubing before I disassemble the loop and paint the PETG tubes to black.
  • SECOND LIEUTENANT
« Reply #11 on: 12-July-16, 19:20:02 »
I'm making a custom support bracket for the GPU.
  • SECOND LIEUTENANT
« Reply #12 on: 12-July-16, 19:20:34 »
custom rad and fans...
  • SECOND LIEUTENANT
« Reply #13 on: 12-July-16, 19:21:30 »
the custom water channel. this will connect the gpu and cpu water blocks.
  • SECOND LIEUTENANT
« Reply #14 on: 12-July-16, 19:22:52 »
keeping everything clean.
  • SECOND LIEUTENANT
« Reply #15 on: 12-July-16, 19:24:35 »
and a quick preview of the internals.
  • SECOND LIEUTENANT
« Reply #16 on: 13-July-16, 00:58:58 »
more updates plus the finished custom loop.
  • SECOND LIEUTENANT
« Reply #17 on: 15-July-16, 16:51:13 »
more pics, finished wiring the internals today.
  • SECOND LIEUTENANT
« Reply #18 on: 15-July-16, 16:54:35 »
front panel bits and pieces.
  • SECOND LIEUTENANT
« Reply #19 on: 15-July-16, 16:56:17 »
  • SECOND LIEUTENANT
« Reply #20 on: 15-July-16, 20:28:17 »
got enough RGB leds to light up the entire house.
  • SECOND LIEUTENANT
« Reply #21 on: 16-July-16, 17:06:11 »
RGB test:
  • SECOND LIEUTENANT
« Reply #22 on: 16-July-16, 17:16:09 »
Radioactivo2
SPECS:
-Intel Core i7 6700k
-MSI Z170 Pro Carbon
-MSI GTX 960
-Corsair Dominator DDR4 16GB
-Corsair Force LS 480GB SSD
-Corsair H110i (modded)
-Corsair RM 750i
-Corsair Carbide 600C
-Watercool Heatkiller CPU block
-EK Thermosphere GPU Block
-Custom Bayres/Pump
-FTWindustries Fittings
-FTWindustries PETG Tubing
-FTWindustries Custom Sleeving
Worklog link:
https://forum-en.msi.com/index.php?topic=270769.0
click on the pics for hires size :D
romanwar
  • SERGEANT
« Reply #23 on: 05-February-17, 04:51:54 »
Good job
