MSI REWARDS - PARTICIPATE ON MSI FORUMS, GET REWARDS, MSI GameBot - Register your products by MSI GameBot now!
Hi all,I hope I've posted in the right place.I'm trying to install Ubuntu on my GP62 6QF LEOPARD PRO, but everything I've tried the installer hangs and I'm at the end of my tether and I really don't want to used windows!So has ANYONE managed to install Ubuntu on one of these or similar and what do you do to get around installer locks?HelpThanks
Hi David,Thanks for taking th time to reply.Yeah I guessed I may not get a lot of help here, but thought I'd ask the question anyway. I'm still working on my issue, although I have Win10 running on it in the interim, which I've got to say flys.You're staying on Win7, not taking the upgrade offer? As a little advice, I'd take an image of your current build, take the Win10 free upgrade and once that's done restore back to Win7. This will future proof yourself as once you've upgraded to Win10 you can always rebuld t that down the track and your machine will be licensed and you wont have activation issues. You only have until the end of this month to take the free upgrade to BTW. As for imaging I use Acronis, but there are others out there.Thanks againR
For sake of those wanting to help. Can you give a direct link to the exact ubuntu you are using with a download link to download and try install and compare to your problem.The versions of Ubuntu I tried are x64 14.04 up through to 16.04.
Hi,Are you on windows 10? I haven't gotten around to installing Linux on my notebook yet, but I know on UEFI systems, on W10, you have to disable Fastboot in power options....when you are in the installer and you say it hangs, how far into it are you getting? At what point is it hanging?
I've gone through the Linux initiation in the past (being a Windows person for most of my life, unfortunately)...My personal experience has been in learning how to correctly dual boot a Windows 10 host machine with Kali Linux 2.0. I have had similar problems when attempting to install. As (I think Dave or David is his name) the other poster mentioned, whatever flavor of Linux you're trying to install, there is likely a community, wikipedia page or pages and several videos and other How-To media. Not trying to send you away...just want to see you solve your issue...especially when it concerns another person learning and using Linux! :-)The one other guess I would take....when I was having those aforementioned issues that are similar to yours when trying to install Kali, I was trying to install from a thumb drive....is that the media you're using? If so, what program or application are you using to create the bootable flash drive installation media?I found UUI worked the most consistently (as I've done it on a few machines now)...pretty sure that stands for Universal USB Installer)....here's the link: http://bit.ly/1diZnKQ
Sorry I couldn't help you more, bud.
I think your problem is tied to the NVME SSD. I think you were on the right track as turning off secure boot should allow installation of other OS's. But ppl have been having alot of difficulty with these new SSD's, such as the Samsung 950. Try searching for 'install ubuntu on NVMe SSD' and see if you find related solutions
