Author Topic: [MSI PRO MOD - S4] FURY  (Read 5272 times)
mattoc91Topic starter
  • STAFF SERGEANT
« on: 11-July-16, 19:40:10 »
Hi, i'm MooZ from Colombia. You can check about me or my projects in the following links:
fb.me/MooZModZ/
fb.me/MooZModding
After sketching for some time, i finally decided to build my next case mod with a military theme, and mixed with some crazy ideas. This is the first time i build a colorful project, but rgb lights provide a nice touch. Watercooling is also involved, and more.
Here is the list of the hardware:
- Intel core i3 6100
- MSI h110-i pro mini itx
- Crucial Ballistix Elite DDR4 2x4gb
- MSI gtx 970 armor 2X
- Gskill Phoenix III 128gb
- NZXT Hale 90 v2 700W
- Bitfenix Prodigy itx
Stay tuned
  • STAFF SERGEANT
Re: [MSI PRO MOD - S4] FURY
« Reply #1 on: 13-July-16, 00:05:32 »
Disassembled the case, i started to cut around.
Also, the bays for PSU and mobo were removed too. I thought in a new position to show off better.
  • STAFF SERGEANT
« Reply #2 on: 13-July-16, 00:19:52 »
Meanwhile i built two test panels, to check space and support. This also let me to change itx mobo limitation of the case, allowing to use a mini-atx too.
Once everything was checked and tested, the final version of panels were made.
The mobo base works as removable bay, fixed by two screws.
  • STAFF SERGEANT
« Reply #3 on: 13-July-16, 13:55:59 »
This is how it looks...
The SSD is fixed from the rear panel, i drill the holes, then cut a little more hiding from surface.
Anyway, these screws gonna be hidden with a small panel.
Checking the mount holes for the psu, with the bracket, then installed.
  • STAFF SERGEANT
« Reply #4 on: 14-July-16, 12:13:01 »
The vcard and psu cover...
  • STAFF SERGEANT
« Reply #5 on: 14-July-16, 23:41:30 »
Painting panels, airbrushing some and adding other details.
Making a new fan for intake airflow.
Now with the fan controller installed, this is how it should look like
Meanwhile the Power button and usb3.0 ports
it will be fixed at the right side.
  • STAFF SERGEANT
« Reply #6 on: 16-July-16, 06:39:24 »
Two reservoirs for top...
Ran a few hours for leak test and passed.
  • STAFF SERGEANT
« Reply #7 on: 16-July-16, 07:14:09 »
The main reservoir located on top, will connect the different stages of the water cooling, preventing extra hosepipe and as support for the things on top. Divided in two parts, the first one was machining to make the channels, and the other one as closure.
Place other parts together.
  • STAFF SERGEANT
« Reply #8 on: 16-July-16, 11:50:21 »
All the process for the main reservoir is show in the video:
  • STAFF SERGEANT
« Reply #9 on: 16-July-16, 14:14:21 »
Found this screws from a aio watercooling, so i disassembled them and modify a little, to install a better ones.
The mobo cover...
  • STAFF SERGEANT
« Reply #10 on: 16-July-16, 18:52:44 »
Finally, the pilot. Modeled with polymer clay and then airbrushed.
  • STAFF SERGEANT
« Reply #11 on: 17-July-16, 07:26:50 »
Final photos!!
RGB in action!! All the case change with them. Check the liquid coolant how react to diferent colors too :D
Blue-Red-Green-Purple interaction
Hope you like!
  • STAFF SERGEANT
« Reply #12 on: 17-July-16, 14:36:38 »
bonus video :D
tOledi
  • SERGEANT
« Reply #13 on: 20-November-16, 19:38:23 »
Great work!
Bon Jovi
« Reply #14 on: 22-November-16, 01:24:02 »
Perfect broow
Very nice your mod
romanwar
  • SERGEANT
« Reply #15 on: 05-February-17, 04:03:58 »
I like it!
