Pages: [1] 2  All   Go Down
Author Topic: Nahimic and Audio Problems after Windows 10 Anniversary Update  (Read 85524 times)
This topic contains a post which is marked as Best Answer. Press here if you would like to see it.
danielransunTopic starter
Hi. First i would like to apologize if my english is so bad.
My Nahimic audio tools won't open after I update my windows 10 to anniversary version.:undecided:
And also i found that the sound is producing some noises and the quality is declining like if you heard an mp3 sound quality bit rates at 96 kbit/s.
I haven't got a chance to re-install the driver and its software but maybe someone here from MSI might wanna check it out and roll the new update.
Thank you.:hypocrite:
Fyi my Mobo is: MSI Z170 Gaming M7
HenryW
Try by uninstalling Nahimic and audio drivers and then reinstall installing audio drivers first and next install Nahimic, it must be done in that order.
Z77A-GD65/BIOS 10.5, i7 2700K
W 7 Home Premium x64/SP1
Corsair TX650W
Lite-On CD/DVD combo burner
MSI 560 HAWK, Drv. 368.82
rymopar
I have the same problem with the X99A Gaming Pro Carbon.
Re-installing the drivers and Nahimic (uninstall Nahimic, then drivers, then install drivers, then Nahimic) fixes the weird audio sound, but now Nahimic crashes upon launching the GUI
i7-6800k
X99A GAMING PRO CARBON
kam1p0h
I have the same problem with the X99A Gaming Pro Carbon. Re-installing the drivers and Nahimic (uninstall Nahimic, then drivers, then install drivers, then Nahimic) fixes the weird audio sound, but now Nahimic crashes upon launching the GUI
Same problem here
Marked as best answer by danielransun on 04-August-16, 07:35:31
touristhawk
same here too
Edit: After a litte search again I found this. Check this link guys, my problem fixed.
https://www.facebook.com/nahimic/photos/a.1005372326154062.1073741829.965318786826083/1262948373729788/?type=3
same here too
Wow great! thanks for sharing this. i haven't try it yet, but i will soon when i get home :)
rymopar
i7-6800k
eranday
same here too
its working, thx for sharing..
i also have trouble installing any antivirus but windows defender, also experiance app crush once in a while after the anniversary update
dave.n.george
Me too - GT72 2QD Dominator G
darkhawk
  • Online Online
This is good to know.
k.b.karaca
I've solve it. Link and annonced are below. Thank you...
 Thanks to 2.3.0, we fully support Windows 10 Anniversary update and fixed several bugs, including most of the compatibility issues.
 We also added a link in the Sound Tracker tab for you to know which games are compatible with it.
 Requirement : Realtek version 7855 or newer. C-Media laptops : 1.12 or newer, C-Media motherboard : 2.18 or newer.
 Link for Nahimic 2.3.0 : https://mega.nz/#F!AUJXkT5K!51eRg2FSj7p2LfKNvgFPlw
amornik
Guys,
it seems MSI are a bit slow to update the driver section of their website, so go to NAhimic on FB to get the latest (and fastest) updates.
steveineddy
Thanks for this all working fine now.(H170 Gaming M3)
Next task bios update from C3
jcarlos7pt
GE62 2QD(Apache Pro)
Uninstalling Nahimic and audio drivers and then reinstalling them solved my problem.
Laz322
  • SERGEANT
  • "To win without fighting is best." - Sun Tzu.
How do I fix Nahimic 2, it crashes in Windows 10 for me also. Someone mentioned you have to uninstall all of your audio drivers, reinstall the same audio drivers and then install Nahimic 2.
Here's my problem, I don't know exactly which drivers to uninstall? Do I go to Device manager - Audio Inputs and outputs and uninstall everything listed there or should I go to Device Manager - Sound, video, and game controllers and delete everything related to audio in that drop-down list?
Than you.
Board
: MSI Z170A GAMING M5 Bios: E7977v1.A0
CPU
:  Intel® Core™ i5-6600K Processor
MEM
: Crucial Ballistix Sport LT Red 8GB DDR4-2400 PC4-19200 • 16-16-16-39
VGA
: MSI GTX 1060 Gaming X 6GB 192-Bit GDDR5
PSU
: EVGA 500 W1 80+ White 500W PSU 100-W1-0500-KR
HDD/SSD
: 1x OCZ Trion 120GB SSD, WD Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s
COOLER: Cooler Master Hyper 212 LED
Keyboard: Logitech Wireless Keyboard K350
Mouse:
Tt-eSports Razor Ventus Gaming Mouse
fabricioufop
same here too
Thanks!!
7285pablo
This worked for me, thanks.
hatandclogs41
  • FIRST LIEUTENANT
Download the latest Audio Drivers from Realtek FTP.
ftp://ftp3.realtek.com.tw/Realtek/GeneralRelease/
Username:  spcust
Password:  hwwk758z
The latest Realtek Audio Driver is:  7960_PG451_Win10_TH_RS_Win8.1_Win8_Win7 _WHQL.zip
Download latest Nahimic.
https://nahimic.helprace.com/
The latest Nahimic is:  Nahimic 2.3.4.
Uninstall Nahimic and then Realtek Audio Driver, Restart.
Install Realtek Audio Driver and then Nahimic, Restart.
Proper Job. :biggthumbsup:
hatandclogs41
  • FIRST LIEUTENANT
Nahimic 2.3.8 is now Live!
czajkowski16
Re: Nahimic and Audio Problems after Windows 10 Anniversary Update
« Reply #19 on: 01-November-16, 18:15:04 »
thanks mate
Tahbo
  • SERGEANT
« Reply #20 on: 16-November-16, 06:36:41 »
Is it possible to get Nahimic to influence a wireless usb headset?
gunter.rick
« Reply #21 on: 20-November-16, 19:00:28 »
Same problem here.  It never worked at all for my build. I simply uninstalled it.
MSI: z170A MPower Gaming Titanium
Bios: Ver. 1.1, E7A16IMS.110, build date: 07-22-16, applied: 11-18-16
Intel Skylake: core i7 6700-K
Corsair H-80i closed loop cpu cooler
4 x 16gb G.Skill Trident Z F4-3000C14Q-64GTZ
2 x V-nand 950 PRO M.2 NVM Express 512 GB ssd's in RAID-0 Stripe = 1TB capacity
1 x NVidia GFORCE GTX TITAN-X 12 GB DDR5 frame buffer memory
WD Black 1TB rotating drive
Tagan EZ Series 900w PS
Antec 900 Mid Tower case
Logitech G15 K.B.
Logitech MX 518 Opitical
glittersgold808
« Reply #22 on: 16-December-16, 23:04:41 »
Oh my god I was freaking OUT because I just got this computer yesterday (GE72) and the sound randomly started sounding TERRIBLE. I even completely reset my entire computer and almost cried when it finished and the sound was STILL terrible. I could have saved myself so much trouble just coming here. Updating realtek and upgrading to the newest version of Nahimic fixed EVERYTHING! Thank you to everyone who offered help in this thread! Yay! Now I can stop shaking lol.
demonebraithwaite
Hi guys I'm pretty late here but ive run into a problem... ive got the gt72 6qd dominator ive only recently purchased it and everything has been more than great but today windows 10 threw a monster update at me and pretty much after the update my audio is completely :censored: it sounds really poor and it screeches through my headphones to the point where I have to lower the volume down to a tiny fraction worried that I could blow my :censored: speakers ive looked up a few tutorials to no avail ive tried updating all my drivers and ive even uninstalled them in desperation and nothing seems to work I'm just hoping theres something I'm not doing right and it's only a minor issue I don't want to find out theres some trippy problem with my sound card or something that would completely ruin my day I'm going to try to install the old updates for the drivers but if that does not work I don't really know what I'm going to do please guys help a brother out
Nichrome
Your issue is related to Gaming Notebook. This section is for motherboards (desktop PC components).
Make new thread here: https://forum-en.msi.com/index.php?board=71.0
coolpras26
My sound/speakers became very distorted too after the Win10 Anniversary update. Did some research. Followed proper procedure, uninstalled both the realtek and nahimic drivers and re-installed them. The distortion went away. But the sound still sounds supressed and the volume is lower than it was before. I went to MSI and compared the sound to another laptop and YES, the sound in mine does seem low and supressed. I have the latest audio drivers installed. What do I do now??
ant_grasso
« Reply #26 on: 03-February-17, 02:49:25 »
I've had the same problem. Everything is OK after update directly from MSI DATABASE DRIVER. My laptop is MSI GT73VR. Install driver then nahimic 2. [font='Segoe UI', 'Helvetica Neue', 'Liberation Sans', 'Nimbus Sans L', Arial, sans-serif]this driver version already contains the uninstall the previous version program.[/font][/color]
coolpras26
« Reply #27 on: 03-February-17, 05:39:01 »
Database driver? Do you mean the BIOS or something else? Could you please give me the link to it? I have GE62VR
ryan.galbreath
« Reply #28 on: 03-February-17, 23:02:27 »
I also had this problem. Went to MSI website and downloaded MSI Live Update utility. After running the scan I was able to download the updates for all drivers and software, now have no issues.
Hope this helps, as I was a little nervous seeing how I just installed my new Z170 Gaming Pro Carbon on Tuesday...luckily it was just a driver issue and not user installation error.
Pach
« Reply #29 on: 10-February-17, 22:34:59 »
got my issue fixed by installing the latest RealTek driver, wich was posted yerterday on Nahimics facebook https://www.facebook.com/nahimic/?fref=nf , and then installing latest nahimics2 version 2.3.14.
Btw im using a ge62 apache pro.
Gotta admit that the crappy sound was driving me crazy!! hehe
Hello everyone!
We're coming with some good news regarding the cracking noise issue.
Here come the new audio drivers (Realtek and C-Media) that fix this issue.
Please share with us your progress regarding cracking noise issue once you have installed this audio driver.
For Realtek: http://bit.ly/2lnaXyX
For C-MEDIA: http://bit.ly/2kRG1Ga
Enjoy!
henleygregg05
I too had similar problem few days ago.
hamid_m_h
  • SERGEANT
Be careful with msi live update utility. Make sure you check each individual driver update to make sure it has been  detected correctly and at the right driver version. I had some problems before with it so now I'm gonna focus on future updates in this way.
pecassidy
I wanted to share some information with you folks regarding Nahimic, Win10 and two problems I've found and corrected just recently. Although it is still a beta program Armored Warfare with not load with either Nahimic or the Realtek Audio driver which Win10 setup in the latest update this week.. Turning them off in the win 10 start eliminates these two for the game, as well as, 3dmark which is finally able to test my new build. I attempted to utilize the latest drivers and had no luck. It is easier for me to start the Nahimic software when I want to use its features.
MSI 970A Gaming Pro Carbon
AMD FX-9590
16gb ram
GTX1060 oc 6gb GDDR5
1 tb SanDisk SSD
3 tb Seagate Baracuda HD
yuvathejaer
  • SERGEANT
My live update software unable to update Nahimic drivers. Is everyone facing this issue?
rihana.disuza
Apply the below given fixes one by one.
Fix 1 – Reconnect your speakers or headphones
Fix 2 – Reinstall the Nahimic software and audio drivers
Fix 3 – Download the latest version of Nahimic software
Fix 5 – Set the audio to 24 bit format
Fix 6 – Run the Audio Playback Troubleshoot
Fix 7 – Update all your drivers
Vellamoose
  • STAFF SERGEANT
After so many years on my trusted Z87-G45MB which passed away recently, got me a new Z270 M7 Gaming MB & using my loved Razer Leviathan soundbar to be shocked to find out that there do not support 5.1 optical or S/PDIF. All drivers are the latest as per Nahimic webpage. Is there any other options I can use to replace this driver instead of having to stick to it?
Can some guru pls advise?
My Rig:
Intel i7-7770k 4.2ghz LGA1151 @4.5ghz
MSI Z270 M7 Gaming M7
Windows10 Professional 64k
Corsair H100i v.2 Extreme Performance CPU Cooler
Corsair Vengeance 3000mhz 16GB CL15 (4 x 16GB) 64GB
Zotac Amp 1080
Corsair HX1200 PSU
Samsung 960 EVO 500GB NVME SSD X 2
Samsung 840 PRO SSD series
darkhawk
  • Online Online
To be perfectly honest with you, I've never cared personally for the included sound cards on PC's. If it's a PC I care about (like my gaming PC), I'll buy a discrete sound card that provides better output options.
I also prefer having a card that can up convert to dolby digital. Pretty much all built in cards do not have this ability.
The only way to really get this is to get a discrete sound card that does support dolby digital up-converting.
Why do *I* want upconverting? I do, because I want everything to come out in 5.1/7.1 sound. Even my windows sounds, etc....
By having the upconverting, even the Windows sounds come out as 5.1/7.1 because the sound card will upconvert the sounds to the proper signals for my speakers. (As a side note, I have some very old Logitech Z5500 which support multiple inputs and SPDIF/optical) This meant my speakers never made sounds when switching from 2 channel to 4channel to 5.1 channel sounds (which happens if you can't upconvert) and was consistently outputting sound properly.
If you can't upconvert, the audio output will only output the same as the source audio. So if you have a stereo music file that you're playing, it'll come out as stereo (assuming you don't use mods to make it output to multiple channels, etc...). Same with games, etc....
Personally, I use an Asus Xonar U1 for my laptop and an older Asus Xonar board for my PC.
Vellamoose
  • STAFF SERGEANT
Yeah, looks like this may be the way to go for this issue
My Rig:
Zotac Amp 1080
Corsair HX1200 PSU
kilometrez
Hi, i have the same problem. My mic got stuck in very low volume and there is a constant  buzzing from it.  I tried many things whats finally the solution? I cant open realtek manager...
Vellamoose
  • STAFF SERGEANT
Ok guys a quick update.
I got help from the folks from Nahimic & seemed like what they suggested to me worked.
Basically, uninstall current Realtek & the Nahimic drivers & reboot.
Then reinstall this Realtek version:
https://www.dropbox.com/s/4y1k8nwyiefxyub/8233_FF03_PG463_Win10_TH_RS1_RS2_Win8.1_Win8_Win7_WHQL.zip?dl=0
and reboot again
After that install the Nahimic 2 driver:
https://s3.eu-west-2.amazonaws.com/nahimic/Nahimic+2.5.19.exe
and reboot again.
Problem solved for me in S/PDIF. No more cracking noises, bass is nice & tight now.
Hope this can be helpful to those who need it.
Tks to the helpful folks in Nahimic:biggthumbsup:
My Rig:
Zotac Amp 1080
Corsair HX1200 PSU
Vellamoose
  • STAFF SERGEANT
« Reply #40 on: 07-September-17, 03:17:31 »
Latest update on these drivers:
I realised a short while ago that my Razer Leviathan went MONO on me.
I was worried if it was my hardware that went kapoot or was it another problem with the drivers. Namely Nahimic & Realtek?
I uplugged my optical cable & replugged. No difference still mono.
I decided to look at my nahimic mgr to realise that device properties shows blank
I then decided to uninstall nahimic & realtek to run my system on default MS Digital Audio
Everything is working fine, normal & actually sounds livelier. Weird
As a result, I hv decided that I am not going to reinstall realtek & nahimic.
As I am typing this, I'm still running on default MS audio device.
I hv also shared with Nahimic on this prob & my course of action in FB & informed them that I will not be using their driver ANYMORE n will stick to this default device + sharing this info in this forum with link posted to them.
As a MSI gaming MB user for years & years, I feel compelled to share to the global community of this problem that seems to be posted everywhere.
Hv fun ya'll
My Rig:
Zotac Amp 1080
Corsair HX1200 PSU
Nichrome
« Reply #41 on: 07-September-17, 13:44:44 »
Nahimic is something I personally avoid. Got in my motherboard, so I use dedicated sound card which I bought 2 years ago, also got it in my notebook, so I use Asus Xonar U3. Problem solved for me :)
darkelfbear
« Reply #42 on: 12-September-17, 23:48:04 »
I can't even install it even with the most recent drivers from realtek, Nahimic won't even install on my X370 gaming plus. Even though the website for this board says it is supported.
tigre92
« Reply #43 on: 14-September-17, 03:35:11 »
Seems your model is not compatible, look the driver download: https://www.msi.com/Motherboard/support/X370-GAMING-PLUS
brian.ghwt
« Reply #44 on: 21-September-17, 13:06:17 »
I'm also having all sorts of problems with Nahimic and Windows, it doesn't matter which version, which driver, nahimic only stays on the system tray, if I try to open it, it never shows up, I already installed in every order, support only told me to format my PC, they weren't of any help. the worst is that I can't even use the Realtek control panel, i'm really hating this experience with MSI.
My board is the Tomahawk Arctic B350
p373r66
I'm also having all sorts of problems with Nahimic and Windows, it doesn't matter which version, which driver, nahimic only stays on the system tray, if I try to open it, it never shows up, I already installed in every order, support only told me to format my PC, they weren't of any help. the worst is that I can't even use the Realtek control panel, i'm really hating this experience with MSI. My board is the Tomahawk Arctic B350
Same problem here on my X370 XPower Titanium, Nahimic is dead and no Realtek control panel anywhere, tried countless of different drivers & clean installs of Windows. Only solution is to buy an external sound card
Jcarax
  • CORPORAL
After I updated to the newest version, windows asks permission to start Nahimic on start up. It used to work fine before.
alexandre.a.borelli
« Reply #47 on: 21-November-17, 10:24:55 »
My Realtek + Nahimic combo also gives me crackling/popping sound. Windows default driver works perfectly. I tried to reinstall drivers in correct order, format Windows, try different headsets and also both front/back 3.5mm audio inputs. I have a Z270 MSI Gaming Pro Carbon and this :censored:  is just annoying to deal with. I even tried checking my hardware latency and it is perfect. Something is definitely wrong with these drivers.
bboynitrous
« Reply #48 on: 22-November-17, 23:55:13 »
I've found the same problem as alexandre.a.borelli with the latest drivers and a Z170 Krait Gaming 3X. I have a lot of crackling and popping, ASIO driver fails to install, and video goes out of sync with audio on most Chrome and I've never had this issues before. I've reinstalled the drivers many times and have fresh formatted with the Win10 Fall update. Same issues. Only fix has been to uninstall it all and just use the basic windows drivers.
BoutTime
  • SERGEANT
« Reply #49 on: 09-December-17, 10:02:45 »
After completing my X370 Gaming Pro Carbon with a Ryzen 1700, all games suffered from low FPS and awful stutter. I figured it was a hardware issue and tried absolutely everything I could think of. Then I started to look at peripherals and drivers and started to uninstall/re-install them. LatencyMon  also showed no driver issues. Eventually I decided to uninstall the Realtek and Nahimic drivers and software and all of a sudden my FPS shot through the roof and all games were silky smooth. It was exactly how I was hoping it would be when putting together my build. I should have known it would be the Audio drivers as I had similar issues with my Asus ROG laptop.
I reinstalled both Realtek Drivers and Nahimic software and although performance was still pretty much the same with high FPS and no stutter, every now and then FPS would dip a little. So I uninstalled both again and then re-installed only the Realtek drivers. So far it's been faultless. So I've decided to give Nahimic a miss and leave it uninstalled.
Pages: [1] 2  All   Go Up
