Author Topic: MSI BurnRecovery ISO files  (Read 19616 times)
hossein.gTopic starter
« on: 19-August-16, 22:54:36 »
I made a backup from my WS72 6QI-026US using MSI BurnRecovery and selected ISO image.
Now I want to use this backup and tried to burn them on DVD but one of ISO images requires DVD 9.
I tried to make a bootable flash from first ISO using RUFUS, the system starts up and shows a window of recovery message then restarts in a loop.
How can I transfer or convert the ISO recovery files to USB flash?
MHG
runningman
  • CAPTAIN
Re: MSI BurnRecovery ISO files
« Reply #1 on: 22-August-16, 20:29:42 »
That is not the correct way to use Burnrecovery media.  You need to rebuild a USB recovery media by MSI burnrecovery again, otherwise it can't work if you transfer ISO file to a bootable USB.
Check out these FAQ and build a USB recovery media.
How to use MSI BurnRecovery on Windows 10 preloaded system?
https://www.msi.com/asset/global/picture/faq/10015490@2016-0401-1056-095238@faq_0000000001779_en.pdf
How to use F3 Recovery on MSI Windows 10 preloaded system?
https://www.msi.com/asset/global/picture/faq/10015490@2015-0817-0741-080040@faq_0000000001774_en.pdf
« Reply #2 on: 22-August-16, 23:13:22 »
Thank you for your reply and the references.
At this point I just installed Windows 7 on the system and can not backup Windows 10 on USB. But the new version of CAD software that I use will be compatible with Windows 10 in 1st quarter 2017 and I want to switch to Win 10 then.
Is there any utility that converts BurnRecovery ISO images to USB flash?
For Windows installation images there are several utilities like "Windows 7 USB DVD Download tool" from Microsoft and "RUFUS", but none of them work with BurnRecovery ISO images.
With regards,
MHG
hatandclogs41
  • FIRST LIEUTENANT
« Reply #3 on: 23-August-16, 17:51:17 »
hossein.g, Burn Recovery only creates Recovery Files for a Windows 10 install.  Found that out the hard way myself.
But the good news is that you can Download Genuine Windows 10 Insallation Media directly from Microsoft.
You shouldn't need a Key to install as well, as you should have an SLP (System Locked Preinstallation) Key in the BIOS / UEFI.
Hope that you find this information useful, good luck.
« Reply #4 on: 23-August-16, 21:43:14 »
hatandclogs41, thank you, this will resolve my issue.
With regards,
MHG
runningman
  • CAPTAIN
« Reply #5 on: 24-August-16, 00:22:17 »
Hi Both,
One thing I have to remind you is that not only the DPK key in BIOS is required to activate WIN10, you also needs to use OEM preinstalled Windows system, therefore the OS will not activate if you install the ISO file from Microsoft.  Retail version is different from OEM version.
« Reply #6 on: 24-August-16, 00:57:39 »
Hi runningman,
So I have to use the backup that I have.
Any suggestion for loading ISO to USB flash?
MHG
hatandclogs41
  • FIRST LIEUTENANT
« Reply #7 on: 24-August-16, 22:41:53 »
runningman, the SLP Key will activate a downloaded Win 10 Installation Media.  Just as OEM.
When I downloaded a USB Install Media, I was not prompted for a Key during setup.  And as it is valid Win 10 it will show as activated when Windows loads.
runningman
  • CAPTAIN
« Reply #8 on: 25-August-16, 00:13:25 »
Hi runningman,
MHG
I think you can still try the solution hatandclogs41 suggested, and share us your test result, thanks.
Microsoft “MediaCreationToolx64.exe” tool.
https://www.microsoft.com/en-us/software-download/windows10
« Reply #9 on: 02-September-16, 12:22:42 »
Thank you runningman,
I do not want to upgrade to Windows 10 right now. But I will try it in a few months and will share the result with forum.
With regards,
MHG
ezeoragodswill
« Reply #10 on: 11-March-18, 08:11:51 »
SOLVED, To convert your multiple recovery ISO image into a bootable flash drive, watch this video that I have created to explain the steps in details:
And you can also watch how to fix reagentc false error, in my up coming videos.
feel free to ask any questions or help.
I hope, this was of help to you.
bethunexweixci
« Reply #11 on: 10-December-18, 00:43:41 »
Curiously,one of ISO images requires DVD 9 .....
I have never used the Rufus for burning iso ,i need a simple tool more than anything else.
