Author Topic: adding a 5.1 card to mega pc...  (Read 4301 times)
amangill1984
« on: 30-August-03, 12:43:42 »
Just added soundblaster live 5.1 to my mega pc (p2 2.4)
any way which i can get the hifi to use the soundblaster 5.1 card instead of the onboard sound?
thanks
Maesus
  • in Penang, Malaysia
(No subject)
« Reply #1 on: 30-August-03, 13:05:10 »
  • Best Answer
  • 1. turn off PC, plug the card in, turn on PC
    2. goto BIOS and disable onboard audio
    3. boot to WinXP and install the SBLive driver, download the driver updates from Creative website make sure you have the newest one.
    4. you have all the good audio but lose the "CD Audio playback without turning on PC" feature.
    Please read the ==>MOAN Guide<==
    Maesus
    My PC:
    Now using : IBM Thinkpad T60p
    Core 2 Duo recipe
    E6600 2.66Ghz with GB Rocket Cooler Pro : MSI 975X Platinum PUE BIOS 7.6 : DDR2-667 2x1GB + DDR2-800 2x1GB : MSI 8800 Ultra : 80GB WD Caviar SE : Maxtor 250GB SATA : LiteOn LH-20A1S DVD writer + Samsung SH-W162C DVD writer : MSI Theater 550 Pro : LOGITECH Z-680 : DELL E228WFP 22" LCD : PowerLogic 500W PSU with +12V1&+12V2 @ 32A total
    amangill1984
    (No subject)
    « Reply #2 on: 30-August-03, 15:03:26 »
    right i have disabled onboard sound in BIOS.
    Installed th correct drivers
    but still when i turn off the pc and put it in hifi mode, it doesnt work (the sound that is)
    THE SOUND WORLS FINE HOWEVER IN PC MODE
    amangill1984
    (No subject)
    « Reply #3 on: 30-August-03, 16:22:11 »
    is the msi hifi even 5.1 compatible?
    amangill1984
    (No subject)
    « Reply #4 on: 30-August-03, 16:36:54 »
    also, what do you mean by
    NovJoe
    (No subject)
    « Reply #5 on: 31-August-03, 03:27:32 »
  • Best Answer
  • Mega PC is supposed to build up as to enable listens to music like a mini compo hifi, turning onboard sound and sloting in your 5.1 sound card and enable to hifi mode will cause the Mega PC to disable this function aka you have to switch it on the PC way for CD Audio Playback instead od Mega PC standalone Power on.
    All the Best... :D!!!!
    MSI HQ Forum USB flasher
    amangill1984
    (No subject)
    « Reply #6 on: 31-August-03, 04:37:40 »
    soory m8 i dont understand what u said
    NovJoe
    (No subject)
    « Reply #7 on: 31-August-03, 04:40:08 »
  • Best Answer
  • It means that Mega PC actually acts like a mini-hifi system standalone with the features of a PC when you throw the needed components in ;).
    Wonkanoby
    (No subject)
    « Reply #8 on: 31-August-03, 04:39:13 »
  • Best Answer
  • its only ever going to work in the other mode with onboard sound
    if you want to use different hardware then pc mode will need to be used
    P5Q Deluxe
    Intel QX 6700
    4GB OCZ
    60 GB Vertex drive
    ATI 5850
    amangill1984
    (No subject)
    « Reply #9 on: 31-August-03, 05:31:35 »
    right, so basically, if i just want to use the hifi function alone, then i have to use the onboard sound?
    NovJoe
    (No subject)
    « Reply #10 on: 31-August-03, 09:38:47 »
  • Best Answer
  • Yes ;).
