Author Topic: 2 Questions on the Aegis-001BUS  (Read 832 times)
gavinremTopic starter
« on: 02-December-16, 08:48:05 »
I just got the MSI Aegis-001BUS (100 chipset) on a great deal and I have two questions on it. First is there any way to upgrade it to the Z170 chipset motherboard that comes with the Aegis X-001BUS barebones. They appear to be the same case. And Second, I see MSI has upgraded the 100 chipset motherboards to support Kaby Lake processors. Does this apply to Aegis-001BUS as well?
Thank you all for your time.
Yang
  • AIO Moderator
Re: 2 Questions on the Aegis-001BUS
« Reply #1 on: 04-December-16, 18:49:22 »
1.Aegis and Aegis X are used special motherboard so if you want to upgarde motherboard, must be contact RMA to buy it.
P.S. Maybe power supply are also different and msut be upgrading together.
So i not suggest upgrading motherboard.
2.At this moment, it is still not support Kaby processors.
