Author Topic: Msi Gaming M3 Z170A unboxing  (Read 874 times)
altansenerTopic starter
« on: 02-January-17, 04:15:49 »
Perfect compatibility with MSI Gaming M3 Z170A and Intel 6700K.. :)
Unfortunately there is no graphics. I'm using onboard right now.
im using hd graphics 530
- removed turkish part -
(If Turkish buddies are limited, use MSI Gaming M class based on the motherboard, and in addition to the hd graphics 530 Apu provided by Intel i7
You will be able to use your system until you get your budget flat. I have experienced many games with this demand. First of all there is fluency in 8GB Ram and obvious low level games. Depending on the graphical tiredness in the middle level, the game stream is entering the narrow bog. With 16 gb Ram this falls a bit, but the table does not have a graphics card. Personal recommendation you will be expecting a smooth gaming experience with NVidia, which is fully compatible with the Msi Gtx 1060 or 1070 system. Now, in the review section, I am having problems installing the Hd Graphics 530 driver in W7 and W8 installations in these systems. So the new system wrote the new software logic and driver.)
  • 微星科技
Re: Msi Gaming M3 Z170A unboxing
« Reply #1 on: 02-January-17, 06:34:23 »
Turkish language parts removed. The forum language is English and only to be used. >>Please read and comply with the Forum Rules.<<
Also moved thread to review section as there is no unboxing included.
AMD Ryzen 9 3900X
Windows 10 Pro
