Author Topic: L Key is not working  (Read 1391 times)
tytheminerkappaTopic starter
« on: 05-January-17, 13:42:07 »
   My l key has stopped working and I can only type it by pressing shift + l,
I don't understand why it doesnt work if I don't press L on it's own.
   I'd really like some help from forum staff or anyone to be honest.
I just want the solution to work : /
My keyboard is a
Interceptor DS4100
akst.louis03
  • SERGEANT
Re: L Key is not working
« Reply #1 on: 05-January-17, 18:00:00 »
Have you tried uninstalling your drivers and restarting your PC, or updating your drivers?
Also you really should have your specs >>Posting Guide<<
Main Board: ASUS A68HM-K
Bios Version: 15.03
Video Card: Radeon RX 480 Gaming X 8G
PSU brand and model: Thermaltake TR2 600W
12v rail Rating of listed PSU: ATX 12V 2.3
CPU: AMD Athlon X4 870K Quad-Core
Memory: Kingston HyperX Fury 8GB
SSD/ HDD: Samsung SSD 850 EVO 250GB Western Digital Blue WD6400AAKS (HDD)
Keyboard: AULA SI-859
Mouse: Logitech Performance MX
Operating System: Windows 10 64 Bit
karnik.akshay
« Reply #2 on: 30-May-17, 17:14:23 »
Try pressing the key in boot mode, just to see if its really a hard ware issue.
If its not working, contact the MSI tech support and they can probably get your keypad replaced.
dport78
  • STAFF SERGEANT
« Reply #3 on: 17-August-17, 02:40:27 »
Did u get it working?
hakanucar1990
« Reply #4 on: 26-December-18, 12:04:19 »
this is exactly whats happening to me now. is there any solution? (GL72 6QE)
darkhawk
« Reply #5 on: 26-December-18, 15:20:15 »
Do you have a DS4100? If not, it's not even remotely the same.....the GL72 6QE is a notebook and uses a Steelseries (I believe....) type keyboard. You really should be making a topic within the notebook section then if that's the case.
System 3MSI Z390 GodlikeIntel i9 9900K32GB DDR4 @ 3600 MHz MSI RTX 2070 Gaming Z 8GB
