Author Topic: UnBoxing MSI 970A Gaming Pro Carbon  (Read 981 times)
ardhany.agung.saputroTopic starter
  • Dendeng Wijen
« on: 09-February-17, 05:37:40 »
MSI 970A Gaming Pro Carbon, AMD AM3+
MSI Performance GAMING motherboards deliver a polished gaming experience. The Performance GAMING series motherboards offer an unique, customizable, design and distinguished look & feel with the best options tailored to gamers.
Carbon-fiber-reinforced polymer is used extensively the world of car racing, where each second counts. Besides its strength and futuristic look, carbon-fiber is also very light for ultimate performance to pursue track records. MSI GAMING motherboards are dedicated to ultimate performance and the best gaming experience. The CARBON motherboards black scheme combines flashiness with sophistication that is sure to make your pc stand out in looks and performance.
The 970A Gaming Pro Carbon gets its name from RGB LED lighting on the SB950 southbridge heatsink, and the PCB ground-layer isolation trace that separates the onboard audio area from the rest of the PCB. Storage connectivity includes a 20 Gb/s M.2 slot, and six SATA 6 Gb/s ports. Modern connectivity includes two USB 3.1 ports (both type-A), four USB 3.0 ports, gigabit Ethernet, and a high-grade onboard audio solution that includes a 115 dBA SNR CODEC, ground-layer isolation, heasdet OPAMP, and audio-grade capacitors. The board is driven by UEFI BIOS, and supports NVMe booting.
For those who enjoy fancy lighting, especially on a custom modded build, MSI’s “Mystic Light” extension allows users to plug in their RGB LED strip to the available 5050 LED onboard header right at the bottom edge of the 970A Gaming Pro Carbon motherboard. RGB LED strips up to 3A power rating are supported. Users can even control their system’s RGB LED settings via MSI’s Mystic Light app on their phone. Customize and set up your own color scheme with Mystic Light. Make your build look on fire or cold as ice. You are in control. You can select any of the colors from the palette to match your systems' design. Tired of always the same color? Just change it to another one using the easy to use Mystic Light APP available on PC, phone and tablet, and make your PC look & feel brand new!. Designed for anyone who simply wants to have a perfectly stylish gaming rig. With MSI's Mystic Light Extension header, it provides the most intuitive way to control the fascinated LED strip without the ordinary controller. Just install the standard 12V RGB strips onto the 4-pin Mystic Light Extension RGB-strip header, then control your lighting to any style you want. Extend the Mystic Light to whole gaming rig and your gaming room.
AMD’s chipset is quite dated so MSI uses 3rd party ASMedia controllers to deliver the extra features. An ASMedia ASM1143 is used for the USB 3.1 support for example and uses ASMedia switches for the M.2 PCIE x4 support as well. The MSI audio boost 3 design integrates a Realtek ALC1150 HD audio codec with dual Texas Instrument OPA1652 amps and Nippon Chemicon audio capacitors.
With Audio Boost, powered by Nahimic Sound Technology, we're delivering the highest sound quality through the use of premium quality audio components. That way, you can enjoy breathtaking, crystal clear sound and music through 8-channel HD Audio or high impendence headphones and truly dominate the game.
MSI Gaming Device Port is optimized to deliver the best connectivity for high end gaming mice to fully utilize it's speed. This results in a much faster and smoother mouse response in games.
Smart Fan Control gives you complete control of your fans on the motherboard, convenient for gamers and overclockers. Users can real-time monitor the status of the fans, set profiles, and record fan speed.
