Author Topic: (2) 4k @ 60hz displays. WT73VR  (Read 1064 times)
joeTopic starter
« on: 11-March-17, 00:08:07 »
So this workstation is advertized to power 2 displays from the tb3 connection.   The only way was able to acheive this is by utilizing MST by daisy chaining displays.   Which only provides 4k @ 30hz. I called MSI and they confirmed that it would produce (2) 4k @ 60  hz. But could not tell me how it was done.  Using a Plugable  TB3 to dual Display port adapter only powers one display.  Plugable said it is because for some reason MSI motherbords only send 1 display line to the TB3... so has anyone else acheived (2) 4k @ 60 hz through the single TB3 connection?  As of right now i am thinking this is false advertizing or at least please list 30hz on the info page for the WT73VR ti take away all doubt.   Why only 1 display line MSI?
runningman
  • CAPTAIN
Re: (2) 4k @ 60hz displays. WT73VR
« Reply #1 on: 14-March-17, 03:37:38 »
Hi, I think MSI TB3 spec is mainly from INTEL.
https://thunderbolttechnology.net/thunderbolt-3-infographic
And if MSI can get INTEL TB3 certificate, that means their TB3 feature has been approved by INTEL.
Just like the list in INTEL TB3 product show case.
https://thunderbolttechnology.net/sites/default/files/16-379_Thunderbolt3_Bro_HI.PDF
As for your adapter signal, it is just my guess, maybe the adapter compatibility is not as good as a TB3 docking, since INTEL is mainly using TB3 docking to demonstrate the extension ability.
