Author Topic: New to MSI and forum  (Read 2720 times)
mobone51Topic starter
« on: 10-April-17, 16:05:03 »
Hello fellow forum members,
I have recently purchased a MSI WT72 6QL-400US laptop. I am extremely pleased so far from what I have seen. I have two questions;
1. I am getting message telling me I should upgrade thunderbolt, should I upgrade the BIOS first?
2. I am trying to use the BIOS update tool but am instructed to remove the battery after a BIOS update. won't that void my warranty since I have to remove half of all the other components to get to it. I have also entered the specs below: I appreciate any advice or help offered.
System Information
Serial Number:                9S7178212400ZG2000002
Product Name:                 WT72 6QL
OS:                           Microsoft Windows 10 Pro 64-bit
Windows Product Key:          QGPKC
HDI Build:                    ZS7-1782TM4-CW1   3.TC4.A13.13.0.1
BIOS Version:                 E1782IWS.113
BIOS Release Date:            2016/01/08
EC Version:                   1782EWS1.1031106201514:51:42
CPU:                          Intel(R) Xeon(R) CPU E3-1505M v5 @ 2.80GHz
Memory:                       32 GB @ 1066 MHz
                               - 8192 MB, DDR4-2133, SK Hynix HMA41GS7AFR8N-TF
Graphics:                     NVIDIA Quadro M4000M, 4096 MB
VBIOS Version:                84.04.83.00.0d,4194304
Drive:                        SSD, Samsung SSD 850 EVO M.2 500GB, 465.76 GB
Drive:                        HDD, HGST HTS721010A9E630, 931.51 GB
Drive:                        HDD, Realtek PCIE Card Reader, 119.08 GB
Drive:                        HDD, PNY USB 2.0 FD      , 15 GB
Network:                      Killer E2400 Gigabit Ethernet Controller
Network:                      Bluetooth Device (Personal Area Network)
Network:                      Intel(R) Dual Band Wireless-AC 8260
runningman
  • CAPTAIN
Re: New to MSI and forum
« Reply #1 on: 12-April-17, 01:50:28 »
Hi, since your Notebook battery is built-in within the mechanical, I don't think you need to remove the battery.
As I know, MSI BIOS already have auto reset feature after you flash it at the first time.  And from your information, you need to update BIOS to ver. 118.
« Reply #2 on: 20-April-17, 15:49:02 »
Thank you for responding.  I was able to get the .118 BIOS installed. The people at Tech Support were great!
Hutbolzen
  • SECOND LIEUTENANT
« Reply #3 on: 18-August-17, 11:15:46 »
System Information
Hello
It is possible that You send me the Vbios of Your M4000M please?
« Reply #4 on: 19-September-17, 15:53:58 »
Hello joerg-hohmann,
Thanks for replying to my question. I was able to update the BIOS with no issues. To answer your question, the VBios version for the M4000M is 84.04.83.00.0D.
Hutbolzen
  • SECOND LIEUTENANT
« Reply #5 on: 21-September-17, 12:03:15 »
Hello
Thank You for Your reply,but i need the Vbios Rom.
Could You save it with Gpuz and upload here please?
