Author Topic: GTX 1060 Gaming X fan problem.  (Read 702 times)
sashawitwerTopic starter
« on: 24-April-17, 06:59:47 »
One of the fans on my GTX 1060 Gaming X doesn't always start spinning, it's just twitching in effort to start. This happens approximattely one-two times in ten game sessions. I read I should RMA the card, but this is a very painful process in my situation. Actually even with one fan spinning temps hardly excede 70c and the malfunction happens as I investigated only when the fan stops in some dead zones - if I spin it several millimeters clockwise it starts with no problems. My question is:  if I decide to leave things as they are, is there any risk this faulty fan breaks down completely since voltage is applied to it and it doesn't spin ???
Nichrome
  • Online Online
Re: GTX 1060 Gaming X fan problem.
« Reply #1 on: 24-April-17, 07:02:34 »
Hi
I suggest you RMA the card, it is the only way to get it fixed.
Also can you please provide full S/N of the card?
Thanks
https://valid.x86.fr/mbld36
« Reply #2 on: 24-April-17, 07:09:01 »
S/N: 602-V328-010B1612031799
So what about the fan? Is it safe like this? Or will it burn eventually?
Nichrome
  • Online Online
« Reply #3 on: 24-April-17, 07:36:21 »
Unsure to be honest. But it does not function the way it should, so RMA is the only way to get it fixed.
