Pages: 1 2 [3]  All   Go Down
Author Topic: AMD AM4 Ryzen Overclocking Guide (X370 and B350)  (Read 135880 times)
darkhawkTopic starter
Oh i almost forgot a question. I can't find any offset changing at the Voltages, i can just put fixed voltages, is it normal ' Thanks.
MSI hasn't implemented any 'offset' or 'adaptive' voltage settings for the AM4 series.
If you want a mode similar to that, your best option is to leave it set to AUTO.
Otherwise, set a static voltage and that's it.
mmosrc
  • CORPORAL
Re: AMD AM4 Ryzen Overclocking Guide (X370 and B350)
« Reply #101 on: 28-September-17, 04:29:13 »
Good to know, thanks!
kaarelvirroja
« Reply #102 on: 03-October-17, 00:58:01 »
Did MSI change something with latest BIOS updates?
Default MB boost gives only 3.6 Ghz but previously it was 3.8.
gu.munoz
  • SERGEANT
« Reply #103 on: 12-October-17, 19:35:29 »
Hey Guys,
I think my CPU is a very bad overclocker, I set the CPU voltage as 1.38v as in this post and I try the multipler 38 - to of course get 3800 mhz - when I hit F10 and save - I get a instant lock up and the system does not boot up - so I have to clear the CMOS - anyone got a similar case? my CPU in general runs around 3.6-3.7 and XFR at 3.9 sometimes, In other thread a saw a guy with the same mobo facing the same problem - whenever he set the multipler to anything else than auto - he has the same behavior
Regards,
Gustavo Muñoz
gu.munoz
  • SERGEANT
« Reply #104 on: 16-October-17, 11:18:22 »
Hello Guys,
Note sure how to edit my last message - I could get it stable the 1500X@3.9 vCore: 1.3875v and RAM @2933 (v1.36) @16-18-18-18 - it not stable @ 3200 and 3.9 so it leads to the black screen after saving in BIOS :)
 - the best CINEBENCH score was 839 - with default (3.5 and 3200) it was 739 - so I prefer this configuration than stock.
Regards,
Gustavo Muñoz
haunter528
« Reply #105 on: 09-November-17, 15:25:29 »
It's my first time OC any PC. I have the x370 Gaming Pro Carbon and a Ryzen 1800x. I have try using Command Center from MSI and a little after I applied the changes to reach 4.0 GHz the screen goes black, mouse and keyboard stop responding and I have to hit the power button and turn on again, when I get back to windows I am back at 3.6 Ghz. Also I have try the application from AMD. I have up on both applications and try the BIOS option, I set the speed to 3.8Ghz and volt to 1.3 or 1.4 and reboot and nothing, I am not able to get into the BIOS, I see the LED from the motherboard but nothing. I have to remove the power cable and BIOS battery to start the PC again, I have try speeds of 3.8 and 4.0 with voltage of 1.3 and 1.4. Any help or recommendations would be highly appreciated.
Drivers are up to date. Any additional information that you need to know, ask me.
Thanks!
« Reply #106 on: 09-November-17, 16:57:49 »
Thanks!
Not every CPU is going to do great overclocking. Some do well, some don't. You might have gotten a CPU that can't overclock well.
cadientebenson
« Reply #107 on: 09-November-17, 20:07:09 »
Thank you for this detailed OC guide.. Ill overclock my R5 1600 as soon as i get my liquid cooling. This may be stupid question but just wanna ask if the CPU will run at the max speed all the time when you OC it? Kinda worried about power consumption if it does. or is there a setting that can make it run at lower clocks when not using it and it will just boost to max OC speed when needed?
nesty1990
  • SERGEANT
« Reply #108 on: 10-November-17, 11:48:49 »
it is CnQ (Cool´n´Quiet) ... but here is the catch, since MSI motherboards do not have offset/adaptive mode, CnQ will be disabled if you change your vCore to any other value than auto...
On the other hand, core C6 state will still be enabled so idle power consumption wont be much higher, it is only 3-6W more than default settings on my system...
i personally OC´ed memory through the bios and CPU through the Ryzen Master to keep CnQ running to avoid temp spikes (and fan rpm spikes) with help of windows power plans and little utility called Full Throttle Override....
MSI B350 Tomahawk
AMD Ryzen 7 1700 @ 3.85 GHz 1.3V
EK Supremacy EVO, 2x240mm rad, EK-D5
Corsair CMK16GX4M2B3000C15 @ 3000 15-17-17-35 1T
Samsung SM961 128GB NVme
Samsung 850 EVO 500GB
Sapphire RX470 Nitro+ 4GB
Corsair RM550x
http://www.userbenchmark.com/UserRun/7789236
cadientebenson
« Reply #109 on: 10-November-17, 20:17:17 »
I was browsing on tomshardware and i read that you can just re enable the cool n quiet when your OC is stable? Is this really okay?
crazyclicker
« Reply #110 on: 12-November-17, 03:41:03 »
Guys, can you please help me with keeping fans on a normal rate after I've set ram to XMP2 profile with 3000mhz frequency on B350 carbon.
As it mentioned in try it! section mb increases fan speed after 2750mhz, but in my case it's really not necessary as CPU temp dont get higher that 33C. And fans get reeeeealy loud.
« Reply #111 on: 12-November-17, 13:08:46 »
Setup your XMP2 settings. Save. Reboot. Go back into the BIOS, then change the fan settings, save, reboot and that should fix it.
If you follow that procedure the fan settings should stay properly.
crazyclicker
« Reply #112 on: 12-November-17, 13:48:22 »
Thanks! It did the trick, but settings being auto changed each time I visit OC tab, so I guess fan settings should be the last to configure.
Also a question about memory: XMP2 profile states 3000mhz with 15 CAS but in fact sets 2933 and 16. Should I stay on profile and alter voltages or should I manually set frequency and latency?
Btw it's only me who dont have 3000mhz option in manual setup but only 3066? =)
carlo.muzzolon
« Reply #113 on: 11-December-17, 14:01:24 »
Today I read around the web many guides, posts, messages of any kind, saying that leaving VCore on "Auto" results in a uselessly high voltage (far higher than necessary).
Tonight I made my first attempt: I set 3.7 GHz (I want maximum stability), and VCore on "Auto". Well, voltage and frequence scaling work flawlessly, and maximum voltage reached is 1,272, that seems perfect to me.
Did MSI change anything with one of the last bios? At the moment, I wouldn't see any benefit in setting a fixed voltage.
Hemi5.7V8
  • CORPORAL
« Reply #114 on: 16-December-17, 16:50:49 »
My 1500x 3,9ghz at 1.36v on a b350 gaming pro carbon
Alan Slade
« Reply #115 on: 29-December-17, 01:27:15 »
Good morning everyone.
I recently built a 1700x pc with a Msi Gaming Pro Carbon Mobo.
I would like to know why, if I set the XMP to Profile 2, on top of the screen the speed remains at 2133 mhz, when instead in grey is written 3200 mhz (which is correct, as I have Ripjaws 3200 mhz). In the link you can see the image.
Thanks in advance
magxedin46
« Reply #116 on: 14-January-18, 08:55:37 »
Hello guys!
Is it ok to ask a question in this topic or should everyone start a separate topic?
Ihave b350 msi tomahawk + ryzen 1700 + corsair vengence ddr4 2*8 3200
By default it shows both in bios and windows 2133mhz. I tryed setting XMP profile @3200, it results in one boot with 3200 freq, and afterwards it shows both in Bios and in widonws 2133, though still showing as if XMP isactive in bios.
Next  i tried setting another XMP (its 3066 for me), and it works and doesnt drop back to 2133, but now PC starts from 2-4 times (like i push start button it coolers start working then aftert 5 seconds everything goes silent and then starts again).
1) why starting from several attempts happens? How to fix it?
2) why only 3066 works and 3200 doesnt even try?
3) Should i try instead of XMP "try it" mode?
Hope you can help, and this topic is still being read by someone who knows whats up, thank you
BErgao
« Reply #117 on: 11-February-18, 03:35:19 »
I flashed the new bios for my mainboard MSI B350 PC Mate. Why I can't put the CPU voltage below 1.3V? Why is this locked in the new bios 7A34vAA??????
https://www.msi.com/Motherboard/support/B350-PC-MATE
« Reply #118 on: 11-February-18, 07:53:39 »
That's a limitation MSI has instituted. *WE* (ie the moderation team) doesn't know why they instituted this, but that's the way it is.
If it's a huge problem, contact MSI directly via : >>How to contact MSI.<<
pablocol
  • SERGEANT
« Reply #119 on: 17-February-18, 06:23:40 »
Hello guys, i want to make a small comment about the new BIOS UPDATE 7A34v1C.
With the 7A34v19 Bios update i was able to reach 4.0 ghz stable at 1.362v, rock solid, With the new bios update my cpu can not handle 3.9 stable at 1.38. This is not a good stuff because with time, the MSI tomahawk was furbishing incompatibilities that came up with the Ryzen platform. But one year later MSI had an regression with memory compatibility.
Recommendation, ir u are not using an APU, do not Update Bios until they fix this.
TY for reading.
CPU: Ryzen 5 1600 Stock cooler - Stock Freq.
RAM: Gskill RipJaws V 2133mhz 16GB (2x8) - F4-3200C16-8GVKN
GPU: GTX 780 ti EVGA SC ACX
PSU: Thermaltake ToughPower 750 gold 80 plus
SSD: Samsung m.2 951 Pcie 256GB
HDD: Barracuda 500gb 7200 rpm
MOBO: MSI Tomahawk B350 - BIOS VERSION: 7A34v1H
OS: Win 10 pro
KeyBoard: HCMAN - Blue Keys
SoundCard: Steinberg UR22
pablocol
  • SERGEANT
« Reply #120 on: 17-February-18, 06:25:41 »
Did u fix that?
I would try it manual. Maybe is the bios.
OS: Win 10 pro
BoutTime
  • SERGEANT
« Reply #121 on: 20-February-18, 10:56:28 »
Personally I prefer he new Bios and here's why. From what I read you can't set manual vcore for anything below 1.3v. For that, you have to use Auto. The motherboard will then provide the correct voltage (up to 1.3v) with the added benefit that it will down volt when the CPU is idle.
Previously my R7 1700 would only run at 3.6Ghz maximum using Auto voltage (1.214v). To get 3.7 I'd have had to use manual voltage as Auto voltage wouldn't go high enough. I didn't want to use manual voltage as I don't want a constant 24/7 higher vcore.
But now with the latest bios Auto Voltage will go as high as 1.3v meaning I can run 3.7Ghz and the voltage will still decrease when the CPU is idle. So for me it's much, much better. Possibly MSI have realised after 10 months that it is perfectly ok to allow the motherboard to supply up to 1.3v whereas previously they were more cautious.
One very important thing to note though. After updating the BIOS my previous 3.6Ghz overclock wasn't stable anymore. Then my overclock profile would not restore as it apparently wasn't compatible with the new BIOS. I had to reset the CMOS. So I started afresh and that's when I figured out that the Auto Voltage setting now supplies a higher voltage effectively allowing a higher overclock.
isaiahrussell73
« Reply #122 on: 05-April-18, 21:41:09 »
My overclocking specs:
MOBO - Ryzen Tomahawk Arctic B350
CPU - Ryzen 5 1500X @4.02 GHz @1.375 V
RAM - HyperX 16GB 2-stick kit, rated at 2133 MHz OC TO - 2866 MHz Volts on "Auto" cause of POST issues.
I will adjust timings soon.
GPU - ASUS R9 270 OC'd TO - 270X specs
Also, Windows Task Manager for whatever reason shows my CPU @ 3.5 GHz, but CPU-Z shows my OC. But TM shows RAM frequency correctly.
Prime95 was running for a good 15 minutes, and all threads were stable.
This RAM OC especially, was scaring me, cause I at one point had thought I over-volted it cause I had no POST, but turns out I just has to clear CMOS.
Feel free to critique my work. I'm new to this whole overclocking thing. I'm just trying to get max efficiency of my stuff to get my money's worth, you know?
viking_kong
« Reply #123 on: 19-May-18, 03:11:46 »
I experienced the same issue. Out of the box, I didn't encounter this issue. Whenever I overclock the CPU, it shows the correct values on HWMonitor and CPU-Z but not on system properties or DXDIAG. I always update the BIOS everytime there's a new update. So I am thinking that it's a BIOS issue. Luckily, after re-installing the OS, Windows now shows the correct OC values.
SYSTEM SPECS:
MOBO: MSI B350M Mortar
CPU: Ryzen 3 1300X - @3.7GHz auto OC mode
CPU Cooler: Deepcool GAMMAXX S40
GPU: Palit GTX 1060 6GB Dual (Micron) - Core OC + 250MHz | Memory OC + 300MHz
RAM: 8GB (2X4GB) Corsair Vengeance LPX @ 2400MHz - OC 2800MHz
SSD: 120GB Geil Zenith R3
PSU: EVGA 450BV
RicRat2009
« Reply #124 on: 01-June-18, 02:09:31 »
Just replaced the innerds on a old cp with:
x370 Gaming Plus
Ryzen 7 1700x
Corsair Vengeance LPX 3000MHz.
In the bios I was easily able to up the mem to 3000, but the cpu freq is grayed out, I can't change it to a higher freq.  I flashed the latest bios to 7A33v5C, no change.
Anybody know what up?
« Reply #125 on: 01-June-18, 09:13:59 »
x370 Gaming Plus
Ryzen 7 1700x
I would suggest starting a new thread in the gaming motherboards section. You'll get more help in that area rather than here.
I do actually have an X370 Gaming Plus as well, but with a Ryzen 5 1500X.
But.....you need to adjust the CPU Ratio. That'll then update the Adjusted CPU Frequency......
So if you enter 37, the CPU Frequency should show 3700MHz.
Enter 40, the CPU Frequency should show 4000MHz.
RicRat2009
« Reply #126 on: 01-June-18, 15:14:18 »
Thanks for the reply.
I upped the ratio to 39, but had a couple errors in P95 and temps went up to 80c+.  So I will experiment some to see what I can achieve with the cooling I have, CM 212 Evo.
raul.garciaap
« Reply #127 on: 28-June-18, 16:14:00 »
Hi, I have Ryzen 7 1700 with Base Clock 3.0 GHz; my MB is x370 Gaming Plus. So, I want to BOOST but I don't have the option of "CPU frequency" activated, I don't know how to activate it to start overclock. I have the GAME BOOST activated
but it is not recommended to use it. Please help.
Please help me, I really need OC my processor.
« Reply #128 on: 28-June-18, 18:37:39 »
Did you just come here to this post, to post asking for help, instead of even just taking 2 minutes to read the very first post? I mean....it's there. It shows you how to do it. Without GAME BOOST....
hazhheadz
« Reply #129 on: 10-September-18, 20:00:16 »
getting ryzen 1600x - had a8 - 9600 3.2@4.2>3.8 now
have lastest beta bios for b350m pro vdh
just wondering any probs clocking up to 4.3ghz
my ram set to max 2400 of the board...i use 2666mhz memory hoping there be update for overclocking on this board
thanx for the great work
Mik3kY
« Reply #130 on: 12-November-18, 21:34:50 »
i have ram corsair vengeance lpx 3200 (CMK8GX4M2B3200C16) i oc ram to 3200 it can boot but when i open chrome or gta v will getting blue screen i already setting voltage 1.35, 1.36 still getting blue screen
but if i set 2933 it fine but when i open chrome or gta v 2-5 min it will auto closed like end process (not blue screen) i changed timing and setting soc voltage to 1.2 still issue. now i set to 2667 it no any problem i want performance to oc to 3200 but it can't. sorry my bad English
Cpu Ryzen 5 2600 (stock)
B350 Tomahawk lasted bios
corsair vengeance lpx 3200 2*4 GB
power 550 80+
banjo7172
« Reply #131 on: 11-February-19, 12:42:35 »
Hi all,... I have a ryzen 5 1500x on pc mate b350 gaming pro.... cheap but good mobo. running stable at 4350 mhz - 1.45v for the last 4 months all day every day.  , corsair vengence 3200 @3466 1.4v..... I have hit 4525 at 1.5 volts but not stable no matter how cool i get the machine to run. My rig is air cooled. Its summer here so its really hot, but in winter i can run at 4400 all day.
jacksonsimmons7580
« Reply #132 on: 23-October-19, 10:33:05 »
So what would setting would you recommend for a Ryzen 5 3600X and a 2060RTX on a MPG X570? I recently just finished this as my first build and honestly I am scared to do anything to the OC profile without an experienced person recommending me settings.
Nichrome
« Reply #133 on: 23-October-19, 15:27:24 »
Please open own thread as your system is not related to X370 or B350 at all.
Pages: 1 2 [3]  All   Go Up
