Author Topic: 【MSI PRO MOD – S5: Scratch Build】Project V1  (Read 2213 times)
korasekTopic starter
  • Modding its my life
    • Customcase Magazin
PROJECT V1
My Name is : Alex "Gaijin"
Country : POLAND
Hello
I had a few cases but none of them fit me. I decided to do my own thing. I will show you your worklog at the V1 project. 90% of the items are handmade and the material I use is aluminum, glass, acrylic glass. The design of the elements took some time but finally the case started.
inside :
MSI Z170 Titanium
 MSI GTX 1080 Armor
 Intel I5 6600K
 4x 8GB DDR4 ADATA XPG
 2x SSD OCZ 256GB
 1x SSD ADATA SU800 256GB
 1x SSD M.2 ADATA SX8000 128GB
 Coolermaster V1000
 Watercooling ICEMENCOOLING  & EKWB
The whole thing I wanted to fit without a problem in the case, but I did not want it to be great. So I designed two chamber, to keep the heat balance. The first compartment is a motherboard with a graphics card and a water pump and reservoir. In the second power supply, SSDs, radiator.
next
progress
Next Part
to be continue...
Show left panel
MSI-MKT
  • MSI Tech
  • MSI Marketing
Re: 【MSI PRO MOD – S5: Scratch Build】Project V1
« Reply #2 on: 18-June-17, 21:46:09 »
Hi Alex "Gaijin",
MSI PRO MOD S5 will end on 10th July, please SPEED UP your process of mod build.
If you have finished the mod, please reply the following message under the campaign thread (https://forum-en.msi.com/index.php?topic=284238.0) by July 10, 2017 11:59 PM (GMT +8).
MOD entry title
URL of your worklog
In addition, the following evaluation criteria are used for judging at the MSI PRO MOD S5:
  • Creativity: 35%
  • Overall Design: 30%
  • Technique: 25%
  • Worklog: 10%
So, you may take your time to upload more photos with detail description to enrich your worklog to get a high score on "Worklog" criterion.
Thanks
« Reply #3 on: 22-June-17, 11:29:49 »
Finish
Full custom case finish
MSI-MKT
  • MSI Tech
  • MSI Marketing
« Reply #4 on: 22-June-17, 18:53:12 »
Thanks for your participation and such a great mod.
If you have finished the mod, please reply the following message under the campaign thread ( https://forum-en.msi.com/index.php?topic=284238.0 ) by July 10, 2017 11:59 PM (GMT +8).
MOD entry title
URL of your worklog
thanks!
