Author Topic: 1070 GTX rev 1.0/rev 1.2 - how to check the revision number?  (Read 3439 times)
This topic contains a post which is marked as Best Answer. Press here if you would like to see it.
streetTopic starter
  • STAFF SERGEANT
Hey guys
Is there any way to check the GPU revision? maybe on GPU-Z?
Mine looks something like this:
If i was using a 1070 GTX revision 1.2, what would change on gpu-z?
Thank you
P.S
If you have a 2017 build laptop from MSI, you can help me, those laptops come with 1070 GTX REV 1.2
(K1702N K1703N, and so on, check on the box first digits of serial number)
streetTopic starter
  • STAFF SERGEANT
Anyone?
Nidhoggr
  • LIEUTENANT COLONEL
Contact MSI by phone.
streetTopic starter
  • STAFF SERGEANT
Id rather hear from the users first.
It seems the ID Device on GPU Z ends with 11B7 for 1.2 revision gpus.
mangalsuvarnan
Hey Hugo! Been following your posts on notebook review. As a fellow MSi user with the exact same problem (BSOD crash etc) I'd like to know if this is the right way to find out the gpu version! I'm having my card replaced tomorrow and I need to be informed. Thanks man!
mangalsuvarnan
Could you send us a screenshot of your gpu z after your card replacement please?
heyerax
Re: 1070 GTX rev 1.0/rev 1.2 - how to check the revision number?
« Reply #6 on: 24-January-18, 04:55:48 »
Crashing after 20min gaming here, I cant play anymore...
luigimariadimaio
  • SERGEANT
  • Do. Or do not. There is no try
« Reply #7 on: 24-January-18, 13:09:40 »
Hi
I have the gtx1070 with serial that ends with 11B7
Do you want to know something?
MSI GT73VR 7RE
I7-7700HQ, 16Gb Ram, Display Full HD 120Hz, GTX 1070 8Gb
Amaella
  • MAJOR
« Reply #8 on: 25-January-18, 09:49:36 »
I have the 11AF card, no problems with it though... maybe I got lucky but it holds boost speeds nicely and even overclocks some extra. Haven't pushed it yet but it was stable with +100/200.
If you have crashes, you will have to either install the .8A vbios which limits voltage (does not really affect performance much and you can still overclock it) or take it up with MSI, we can't help you here. https://www.msi.com/about/contact-us sadly it is just a user forum. Do make sure they don't just install a vbios that limits the frequency of the card and try to claim that it's fixed ^^.
Previous laptops: Asus K55VJ (i5-3210m, gt635m, 12GB ddr3 RAM, Samsung EVO 850 500GB)
                          MSI GT72VR 6RE (i7-6820HK, gtx1070), MSI GT75 8RG (i7-8750H, gtx 1080)
Current desktops:  i7-8700k, evga 1080ti ftw3, Asus Z370 prime-a, 2x8GB Corsair RAM @3000MHz, Fractal Design Define r6 TG white, Noctua NH-D15
                          i7-7740x, msi x299 raider, msi gtx 1060 armor 6GB, 2x8GB RAM, NZXT h440
If my answers help you out, feel free to help me out by marking them as best solution! Happy gaming to all!
Marked as best answer by street on 12-February-18, 00:55:36
horus137
  • CORPORAL
« Reply #9 on: 08-February-18, 12:34:21 »
The only way is check the gpu hardware...
