Author Topic: B350 Tomahawk BSOD after BIOS update  (Read 2303 times)
ihatepushablesTopic starter
« on: 07-July-17, 09:56:54 »
Hello. I got a B350 Tomahawk. Things were stable until I tried BIOS 1.65.
Then, right after the system launch, I started to get instant BSOD like these:
DRIVER_IRQL_NOT_LESS_OR_EQUAL
 *** STOP: 0x000000D1 (0x0000000000000064, 0x000000000000000B, 0x0000000000000001, 0xFFFFF88000F59C8B)
 *** pci.sys - Address FFFFF88000E0CC8B base at FFFFF88000E00000, DateStamp 4a5bc117
 *** STOP: 0x000000D1 (0x0000000000000064, 0x000000000000000B, 0x0000000000000001, 0xFFFFF88000E0CC8B)
 *** pci.sys - Address FFFFF88000F59C8B base at FFFFF88000F4D000, DateStamp 4a5bc117
 *** STOP: 0x000000D1 (0x0000000000000064, 0x000000000000000B, 0x0000000000000001, 0xFFFFF88000F81C8B)
 *** pci.sys - Address FFFFF88000F81C8B base at FFFFF88000F75000, DateStamp 4a5bc117
The first two came when I tried RAM with 1.35v, its native timings 14-14-14-14-34.
Also the frequencies, for the first one it was 3200, the other one was 2933 or 2667.
(Since I got a pair of 3200 sticks, I tried to make them work faster than 2133).
The third BSOD came when I reset BIOS to default. Then I reset CMOS, same result.
So I tried BIOS 1.6, also with CMOS reset. Same result.
With my OS in safe mode, I got no BSOD. Could mean unsupported video card, but...
My specs:
- Mobo: B350 Tomahawk
- CPU: Ryzen 7 1700 (stock fan)
- GPU: Gigabyte GeForce GTX 670
- RAM: TridentZ CL14 3200 2x16GB
- PSU: ZM 700-LX
- OS: Windows 7 Ultimate 64-bit
Re: B350 Tomahawk BSOD after BIOS update
« Reply #1 on: 07-July-17, 13:27:45 »
Now I checked the same thing but with BIOS 1.71. Same BSOD.
So I changed my Gigabyte GTX 670 to older Asus GT 440. BSOD is gone.
So I would blame a faulty GPU, if only it failed consistently with all BIOS-es.
The point is why it worked with default one and not the updates...
martin.michut
« Reply #2 on: 07-July-17, 13:32:18 »
Try DISABLE C`n`Q option in Bios. I thing that is a BUG. I had a same problem.
« Reply #3 on: 08-July-17, 03:38:42 »
Hey that actually seemed to work. Had one or two more BSODs, then I disabled this and they're gone. Thanks a lot :)
EDIT: Well, no. It was stable for 6 hours but BSOD-ed 10 minutes after I typed this. Still clueless...
« Reply #4 on: 08-July-17, 22:04:23 »
OK the current situation is as follows. I resetted every setting to default.
I get almost regular BSODs in intervals ranging from 50 minutes to 2 hours.
It doesn't seem to matter if I enable or disable C'n'Q. I'll try again without GPU.
If it remains unstable I'll just return this motherboard.
darkhawk
« Reply #5 on: 08-July-17, 23:48:49 »
I would flash back to an older BIOS and see if the BSoD's continue.
You could even try that newest BETA BIOS 1.71 if you wanted.
ServerMSI X370 SLI PlusAMD Ryzen 5 1500X16GB DDR4NVidia Quadro 4000
System 3MSI Z390 GodlikeIntel i9 9900K16GB DDR4 @ 3600 MHz MSI GTX 1070Ti Armor OC
System 4MZI Z390 Gaming Pro Carbon ACIntel i5 860016GB DDR4 @ 3600 MHzMSI 7700 Aero
« Reply #6 on: 09-July-17, 07:57:49 »
I already am on 1.71 and swapped the GPU.
I wrote it before, but my post is greyed out.
Was it moderated or deleted? Is it visible to you?
Here's what I wrote:
But I wrote it just before another BSOD, since then they reappear often.
 I did not yet check BIOS 1.71 with that first card of mine, GTX 670.
Will swap back to it, if it fails I'll flash the old BIOS... Thank you.
« Reply #7 on: 11-July-17, 14:42:41 »
First of all sorry for the huge font of the last post.
(Wrote in low-res safe mode, didn't see the size.)
The current situation on my PC is as follows:
 I did clean Win7 install on a wiped Samsung 840 Pro.
 Then I installed MSI drivers from the CD supplied.
 Then I installed latest GTX 670 drivers from nVidia.
 The outcomes:
 1) instant post-boot BSOD with BIOS 1.71
 2) instant post-boot BSOD with BIOS 1.65
 3) instant post-boot BSOD with BIOS 1.60
 4) with BIOS 1.50:
 - Game Boost works normally, core speed jumps from 3.0 to 3.4 GHz
 - X-AMP freezes the PC, can't even reach BIOS without a CMOS reset
 - Memory Try It at 3200-14-14-14-34 makes CPU-z show as follows:
 a) CPU clock alternates between 3.749-3.199GHz, then stops at 1.5 GHz
 b) memory tab shows default 1066 15-15-15-36 (in fact 2133 since Dual).
 So for me it's a choice between RAM support and GPU support.
 Two weeks of constant issues, I'm past the RMA deadline already.
 $100 is no big money, not my point. I just want to give msi a chance...
 Currently I'm waiting for the official BIOS - but very skeptical...
martin.michut
« Reply #8 on: 11-July-17, 15:11:25 »
Yes, I have a same experience.
With BIOS version 1.5 is system stable and without BSOD.
Version 1.5:
+ stable
- memory speed only 2666, they have OC 3200.
- slow POST-boot
1.6 and above:
+ agesa 1.0.0.6a
+ memory speed 3200
+ fast POST-boot
- randomly BSOD -> DRIVER_IRQL_NOT_LESS_OR_EQUAL / fffff880`00e76d4b / PCI.SYS
  • T9246ED, Бивша комета
  • Administrator
« Reply #9 on: 11-July-17, 17:00:56 »
do >>Clear CMOS Guide<< after flashing to the new BIOS
« Reply #10 on: 12-July-17, 13:04:59 »
I clear CMOS on regular basis, just to make sure. Never helped, also not this time.
  • Administrator
« Reply #11 on: 12-July-17, 14:40:20 »
stick to BIOS that works fine for you then,
and send a feedback to msi here:
>>How to contact MSI.<<
« Reply #12 on: 14-July-17, 07:15:08 »
Did that. After some stability I also had a BSOD on the formerly stable 1.5.
That didn't happen until now, during the last two weeks.
Simply great. If this popped up a few days earlier I would just RMA.
I contacted MSI but I'm not sure if they will still accept that...
martin.michut
« Reply #13 on: 14-July-17, 08:42:16 »
I have two days without BSOD because I installed Win10 instead of Win7. Bios beta version 1.71.
