Author Topic: WS72 6QJ I can't switch to NVIDIA quadro  (Read 986 times)
frederic.rousseyTopic starter
« on: 11-August-17, 07:56:53 »
hello,
i have a WS72 6QJ 28FR and I can't switch to the nvidia quadro card even if I launch applicatoin with "run with performance Nvidia card"
I've intalled the last System Control Manager compatible with windows version 10.0.15063
If I try to run "NVidia control panel" I have a message "NVIDIA Settings are not available. You are not currently using a display attached to an NVIDIA GPU"
In device I see well installes both cards Intel HD Graphics 530 and NVIDIA Quadro M200M
runningman
  • CAPTAIN
Re: WS72 6QJ I can't switch to NVIDIA quadro
« Reply #1 on: 15-August-17, 21:08:50 »
Hi, what's your system configuration?
Would you mind to use "Help Desk" to export it and post here?
http://download.msi.com/uti_exe/nb/helpdesk.zip
You should try latest drivers:
"Uninstall INTEL and Nvidia graphic,
(1). Uninstall Nvidia graphic driver by DDU.
(2). Uninstall INTEL graphic from Windows control panel.
Disconnect network, restart.
(3).Install new INTEL graphic driver.
(4).Install new Nvidia graphic driver."
INTEL KBL/SKL 15.46.02.64.4729
https://downloadcenter.intel.com/download/26941/Graphics-Intel-Graphics-Driver-for-Windows-15-46-?product=98909
Nvidia  385.12
http://www.nvidia.com/download/driverResults.aspx/121781/en-us
How to clean install NVIDIA VGA driver?
https://asset.msi.com/global/picture/faq/10016371@2016-0222-0237-468661@FAQ0000000002110-EN.pdf
And here are some FAQ for your references:
With Nvidia Optimus feature, how do we know Nvidia Graphic GPU is working?
https://asset.msi.com/global/picture/faq/10011896@2014-0415-1059-124561@faq_0000000000253_en.pdf
Set Nvidia GPU for particular programs
https://www.msi.com/pic/faq/10014175@2011-0413-0345-431751@faq_0000000000284_en.pdf
How to switch the graphcis between integrated graphics (iGPU) and the discrete graphcis (dGPU)?
https://asset.msi.com/global/picture/faq/10015790@2015-0422-0258-339852@faq_0000000001659_en.pdf
