Author Topic: MSI B350M GAMING PRO + AMD Ryzen 5 1600 BIOS FAIL?  (Read 2326 times)
justinburhenneTopic starter
« on: 31-October-17, 05:17:19 »
So recently i bought an MSI B350M GAMING PRO motherboard with some ram modules and an AMD Ryzen 5 1600. Now when i built it i used the following components:
-MSI B350M GAMING PRO
-NVIDIA GEFORCE 750TI MSI
-AMD RYZEN 9 1600
-HDD 500 GB
-4X2 RAM MODULES
Now my problem is is that it doesn't even boot at all, not even into the BIOS. So i went and did some research, i found out that the Ryzen apparently doesn't work with my motherboard until a certain update. I don't own another AM4 processor to boot the motherboard and so i can't update the BIOS so that it's compatible with the Ryzen processor. Now my question is: Can i flash the BIOS with a USB stick? Without a processor obviously.
Thanks in advance
Kind regards.
shaunadriaan
Re: MSI B350M GAMING PRO + AMD Ryzen 5 1600 BIOS FAIL?
« Reply #1 on: 31-October-17, 05:29:26 »
Hi i hade the same problem with my pc mate b350 the mobo just need a bois update to support ryzen 5 .i send my mobo back to evetech and thay did the update free of charge and it worked .hoop it helps
  • T9246ED
  • Administrator
« Reply #2 on: 01-November-17, 07:32:24 »
i don't see this CPU in the supported list:
https://www.msi.com/Motherboard/support/B350M-GAMING-PRO.html#support-cpu
AMD RYZEN 9 1600
or you have a typo?
buddyw53
  • SECOND LIEUTENANT
« Reply #3 on: 01-November-17, 07:40:56 »
or you have a typo?
Lessee.... R9 would be a Threadripper.
Pretty sure it's a typo...R5 1600 maybe is meant??  If the board's BIOS doesn't support R5's to let you update to the latest can you take it back to the supplier to get help with an update?
