Author Topic: request msi gtx 1060 6 gb gaming x last bios pls  (Read 6215 times)
mevlutylmaz438Topic starter
  • CORPORAL
« on: 30-November-17, 07:11:23 »
S/N:602-V328-05SB1607014956
nvidia inspector shows samsung memory.
so ı check out other topics people give sn number for bios request is that enough or ?
thanks
  • CORPORAL
Re: request msi gtx 1060 6 gb gaming x last bios pls
« Reply #1 on: 30-November-17, 07:23:40 »
last ı have flash vbios with this https://www.techpowerup.com/vgabios/187788/msi-gtx1060-6144-160920
  • Online Online
  • 微星科技
« Reply #2 on: 30-November-17, 09:27:49 »
Luckily this vbios happens to be a correct one for your card (NV328MH.122). Never use techpowerup as a source for vbios updates. techpowerup can't tell you if it applies to your indivbidual batch of card even if it is the same model.
However there is an update (NV328MH.123) which is attached.
For flashing use nvflash: https://www.techpowerup.com/downloads/2850/nvflash-5-328-0-for-windows
Note that you need to rename the unpacked file NV328MH.123 to .rom (e.g. 123.rom) for flashing.
If you saved the nvflash for windows .exe say under drive d: you can start it in a Windows prompt in administrator mode after you saved the .rom at the same place. First type d: (or wherever you saved nvflash and the .rom) and press enter. Now you changed to drive d: where you have nvflash in the root directory. Now start the flash with the following line: nvflash -6 123.rom (press enter)
Note that if using a 64bit OS you'll need to run the line nvflash64 -6 123.rom
MSI X299 Gaming M7 ACK (MS-7A90) Bios 1.A0
Windows 10 Pro
MSI MAG BUNKER Case
  • CORPORAL
« Reply #3 on: 30-November-17, 11:34:17 »
thanks for fast reply i will not use techpower for vbios again... so ı just save rom and nvflash in same folder, just click on rom and throw it on nvflash64 cmd open I press y and update succes ı think ı did it right way ?
otherside ı get I/O error in cmd so restarted everything is nice thank you very much again.
  • Online Online
  • 微星科技
« Reply #4 on: 01-December-17, 12:09:35 »
:hat tip:
You can save your vbios to file again and we can check if it is successfully updated.
Windows 10 Pro
MSI MAG BUNKER Case
y.bilodid
« Reply #5 on: 16-December-17, 15:49:39 »
Hi!
Can I get an update?
S/N 602-V328-010B1610001582
vbios is attached.
  • Online Online
  • 微星科技
« Reply #6 on: 16-December-17, 17:16:13 »
You are also using NV328MH.122. You can use the updated vbios NV328MH.123 from above too.
Windows 10 Pro
MSI MAG BUNKER Case
dcrawford8
« Reply #7 on: 18-December-17, 23:22:59 »
would i use the same update above?
S/N 602-V328-05SB1607014537
vbios attached
* GP106.zip (150.49 kB - downloaded 183 times.)
  • Online Online
  • 微星科技
Yes. Your card uses the older vbios NV328MH.121 so NV328MH123 is an update.
Windows 10 Pro
MSI MAG BUNKER Case
dcrawford8
« Reply #9 on: 19-December-17, 15:58:22 »
thank you, i figured as much, but wanted to double check. is there somewhere i can find a changelog to see what was actually changed between the versions of vbios?
  • Online Online
  • 微星科技
No, changelogs for vbios are not public.
Windows 10 Pro
MSI MAG BUNKER Case
dcrawford8
« Reply #11 on: 22-December-17, 12:09:43 »
i guess that's why i couldn't find them online, lol.
is it suggested to update the vbios whenever a new one comes out, or should it be handled like most suggest a motherboard bios update is handled (don't update unless something is wrong or need it for CPU compatibility)
  • Online Online
  • 微星科技
Unless there is an issue no need to flash.
Windows 10 Pro
MSI MAG BUNKER Case
jan.schulze
« Reply #13 on: 28-February-18, 11:15:44 »
Hi Flobelix,
could you please tell me, if I can use the above mentioned Version 123 of the VBIOS as well?
Please find my GP160.ROM attached for your reference.
Many thanks and best regards,
Jan
  • Online Online
  • 微星科技
« Reply #14 on: 28-February-18, 12:19:13 »
Em, how should I know. Add the card's S/N else I can't tell.
Windows 10 Pro
MSI MAG BUNKER Case
jan.schulze
« Reply #15 on: 28-February-18, 12:29:41 »
Yikes, I totally forgot that one.
S/N 602-V328-05SB1607025124
Thanks!
  • Online Online
  • 微星科技
« Reply #16 on: 28-February-18, 13:52:13 »
Yes, you can use vbios NV328MH.123 provided above. It would also be an update as you are using NV328MH.122 right now.
Windows 10 Pro
MSI MAG BUNKER Case
jan.schulze
« Reply #17 on: 01-March-18, 09:21:00 »
Thanks a lot!
  • Online Online
  • 微星科技
« Reply #18 on: 01-March-18, 09:39:58 »
:hat tip:
Windows 10 Pro
MSI MAG BUNKER Case
msi
  • CORPORAL
« Reply #19 on: 13-August-19, 14:37:34 »
Serial number PGTWB0B9VBM03H
  • Online Online
  • 微星科技
« Reply #20 on: 13-August-19, 16:16:03 »
Stop resurrecting threads and contact HP for support...
:floblock:
Windows 10 Pro
MSI MAG BUNKER Case
