Author Topic: Beta Bios for the Z170A M7?  (Read 441 times)
dtjamesncaliTopic starter
« on: 18-December-17, 11:02:08 »
are there any new or Beta Bios for the Z170A M7?
If so I would be interested in trying it out.
Current Bios is:   Version 7976v1I
Release Date 2017-05-08
File Size 7.27 MB
Thank You,
David
pandaz
  • CAPTAIN
Re: Beta Bios for the Z170A M7?
« Reply #1 on: 18-December-17, 18:31:57 »
Why do you want to try a beta bios??  Did you encounter any problem?
As normally it is not suggested to update bios if your system is running well.
But of course,  you can contact msi support directly for beta bios.
« Reply #2 on: 18-December-17, 19:22:05 »
I just would just like a new bios or beta bios to update the microcode and Intel Management Engine.
Wishing MSI had a bios with adjustable Load Line Calibration.  There is only one LLC setting basically, Mode 1 (whatever that means and off)
Last time I asked for a beta bios on these forums one of the guys who works for MSI responded and linked me to a beta bios.
