Author Topic: Nightblade X2B-068TW New video card recommendation please  (Read 896 times)
Ranger9cTopic starter
Hi, I have  a Nightblade X2B-068TW system with the GTX960  video card. I am looking for some advice for a replacement video card. I'm thinking a 1060, but I don't know which one would fit.  Any and all advice would be welcomed.
Thanks
HenryW
Re: Nightblade X2B-068TW New video card recommendation please
« Reply #1 on: 26-January-18, 12:17:39 »
See the recommendation list here: >>  Nightblade X2B-068TW support <<
Z77A-GD65/BIOS 10.5, i7 2700K
W 7 Home Premium x64/SP1
Corsair TX650W
Lite-On CD/DVD combo burner
MSI 560 HAWK, Drv. 368.82
« Reply #2 on: 28-January-18, 08:12:38 »
Thanks for the reply, I see on the link you provided the possible configurations. I'll use that as a reference, but not hopeful as it seems the cards listed are no longer available in my area (Vancouver, Canada).
HenryW
« Reply #3 on: 28-January-18, 13:02:49 »
That's just a short list of possibilities, other models of 1060/1070 should work also.
Corsair TX650W
Yang
  • AIO Moderator
« Reply #4 on: 28-January-18, 18:26:56 »
Nightblade X2B-068TW is with 500W power supply for shipping.
So pleaes just use it as below:
GeForce GTX 1060 ARMOR 6G OC
GeForce GTX 1070 ARMOR 8G OC
GeForce GTX 1080 ARMOR 8G OC
« Reply #5 on: 29-January-18, 09:13:37 »
Yang, Thanks for the response. I have checked the website for 2 of the largest video card sellers in my area, and they both say the models you recommend are "discontinued" and therefor they do not have stock. Is it possible to order one of these direct from MSI?
Thanks
HenryW
« Reply #6 on: 29-January-18, 11:21:17 »
I see newegg.ca has the MSI 1070 Armor 8G OC
Corsair TX650W
Yang
  • AIO Moderator
« Reply #7 on: 29-January-18, 18:06:05 »
Please contact your nearest MSI branch office or local distributors for service.
You can find contact info with below link:
MSI branches: http://www.msi.com/about/contact-us/
Distributors: http://www.msi.com/service/wheretobuy/
« Reply #8 on: 30-January-18, 10:01:25 »
Yang, thanks for the response. I have contacted several distributors in my area to no avail. I guess i'm out of luck.
Henry, I looked on Newegg, price is  a bit off for the one seller that has stock. I'm going to go to Canada computers and see what they can do for me. Might have tp put a different brand into this box.
