Author Topic: Hard drive  (Read 900 times)
galveila4Topic starter
Hard drive
« on: 28-January-18, 04:28:41 »
Hi.
How can i change D:\ fron FAT32 to NTFS without erase it?
Thanks.
HenryW
Re: Hard drive
« Reply #1 on: 28-January-18, 05:21:03 »
Normally you can't as you would need to reformat the drive which erases all data. You can try EaseUS Partion Master which should do what you want to preserve data. Read about it and dowload the software here" >> EaseUS <<
 I used that software years ago and it worked pretty good for what I needed.
Z77A-GD65/BIOS 10.5, i7 2700K
W 7 Home Premium x64/SP1
Corsair TX650W
Lite-On CD/DVD combo burner
MSI 560 HAWK, Drv. 368.82
