Author Topic: MSI CORE FROZR XL or Cooler Master V8 GTS ????  (Read 2319 times)
xthemouseTopic starter
Hello, I'm using:
This Case: http://www.coolermaster.com/case/mid-tower/masterbox-5-msi-edition/
This MotherBoard: https://www.msi.com/Motherboard/Z370-GAMING-PLUS/Overview
This Ram: http://www.corsair.com/en-eu/vengeance-rgb-16gb-2-x-8gb-ddr4-dram-2666mhz-c16-memory-kit-cmr16gx4m2a2666c16
CPU: i7-8700
Can they fit?
Will i have a problem with Ram height?
I'm not that into this kind of stuff can you please help me?
Nichrome
Hi
Anything will fit this case in fact.
If RAM will fit, that's another story.
You can check this review:
https://overclock3d.net/reviews/cases_cooling/cooler_master_v8_gts_review/5
With MSI Core Frozr XL, you can fit RAM that is up to 55mm tall.
And your chosen RAM is 44 mm / 1.73 inch tall.
Re: MSI CORE FROZR XL or Cooler Master V8 GTS ????
« Reply #2 on: 04-March-18, 14:33:48 »
Hmmm, nice one of my friends recommend Noctua NH-D15 witch of the three choices is the best option ?? To be honest i don't care how my cooling how looks or RGB stuff ... I just want to be efficient at cooling my CPU
Nichrome
« Reply #3 on: 04-March-18, 14:58:20 »
As you pick just 8700 (non K), it doesn't really matter. All of them are very good coolers.
Personally I'd go with MSI Core cooler. Cooler Master and Noctua are simply very large, and are horrible to mount.
Noctua probably is the best among those 3, as according to reviews, at 5.0GHz overclock on i7 7700k, it keeps CPU around 62C, while MSI one handles is around 70C.
https://www.eteknix.com/msi-core-frozr-xl-rgb-cpu-cooler-review/4/
But then again, 8700 cannot be overclocked, so 1-2C difference is simply nothing.
« Reply #4 on: 05-March-18, 12:10:39 »
Thanks for the advice
Nichrome
« Reply #5 on: 05-March-18, 12:47:12 »
You're welcome :hat tip:
« Reply #6 on: 10-March-18, 09:30:17 »
Soon i will upload when its mounted
« Reply #7 on: 10-March-18, 14:24:47 »
It's working i just had a little problem with closing my case... But it runs fine :)
cubanmafia88
« Reply #8 on: 13-July-19, 12:16:15 »
but can you close the case or not
  • 微星科技
« Reply #9 on: 13-July-19, 13:00:45 »
Don't resurrect old topics...
:floblock:
Windows 10 Pro
MSI MAG BUNKER Case
