Author Topic: b350m pro-vd plus  (Read 728 times)
marius.arazelTopic starter
b350m pro-vd plus
« on: 16-March-18, 13:43:34 »
Just updated the bios for this mobo to the latest version([font=DINPro-Regular, Arial, Verdana, Geneva, 微軟正黑體, sans-serif, sans-serif]7B38v27)[/font][/color], and seems that task manager and system properties are displaying wrong frequency for my ryzen 5 1600.
The cpu is overclocked to 3.7 and auto voltage + cool&quiet disabled, and task manager and system properties shows 3.2 (stock) . Tried to enable C&Q, C state, restore defaults, clear cmos, nothing worked.
I had the [font=DINPro-Regular, Arial, Verdana, Geneva, 微軟正黑體, sans-serif, sans-serif]7B38v22  [/font][/color]before and the cpu frequency was correct so the problem is the bios version and i hope to be fixed in the next version or someone knows a better solution.
  • T9246ED
  • Administrator
Re: b350m pro-vd plus
« Reply #1 on: 17-March-18, 15:13:55 »
check it with CPU-Z
