Author Topic: Straight to BIOS at startup HELP :(  (Read 838 times)
engrjtuTopic starter
« on: 18-April-18, 08:54:42 »
Not sure what happen but after i update everything Win10 Pro, MSI apps via Live update 6.
After restart it goes direct to BIOS and then if i exit it goes BLUE SCREEN.
Let me know if you have any idea.
Thanks
crazycallaway
Re: Straight to BIOS at startup HELP :(
« Reply #1 on: 08-May-18, 10:02:55 »
 Have you checked the boot order of your devices?
« Reply #2 on: 08-May-18, 18:29:28 »
Actually i already found a fix.
Thanks !
crazycallaway
« Reply #3 on: 20-May-18, 17:47:23 »
What was your fix that you found?
