Author Topic: Z370 Motherboard not detecting CPU in the ez debug led  (Read 5584 times)
SasotoTopic starter
This is my first PC build and I followed a guide on YouTube for building my pc. The build was going smoothly, and when I turned it on, all the fans and lights were on.
However, after trying to connect it to my monitor, I found that in the ez debug, the CPU led was lit up. I tried reseating the CPU and checked for any damaged pins, but I couldn't find any. I think it's the power cable I connected for the CPU that is incorrect, but I'm not sure.
The power cable I connected has 8 pin on one end and the shapes match the CPU PWR on the motherboard, but on the other end, there are two 4 pins, but only one of them match the PSU shapes.
Do I have the right CPU power cable? Or is something wrong with my CPU?
I have Z370 Carbon Gaming Pro and an i5-8400.
  • T9246ED
  • Administrator
Re: Z370 Motherboard not detecting CPU in the ez debug led
« Reply #1 on: 18-April-18, 13:29:48 »
can you make a photo of your build?
which cables did you mean?
can you make a photo to show them?
what PSU you are using?
SasotoTopic starter
« Reply #2 on: 19-April-18, 12:54:19 »
Here is my build ( There was no light so I had to use my phone's flashlight) :
https://imgur.com/gallery/HXI3r39
In the picture linked above, I didn't have anything plugged in to the CPU PWR because I don't know if I have the right cable or not.
Here is the EZ DEBUG:
https://imgur.com/gallery/B9Uqf03
Here are the cables that I'm confused about because their shapes don't match the PSU, only the CPU PWR for the 8 pin:
https://imgur.com/gallery/EbJr9
Here is the CPU PWR shapes:
https://imgur.com/gallery/3RjSQgV
My PSU is the ROSEWILL Gaming 80 Plus Bronze 550W Power Supply, the cables were all provided by the PSU.
Nichrome
« Reply #3 on: 19-April-18, 15:04:55 »
Hi
That's why it won't boot up: CPU does not get any power.
Here's your PSU's manual:
https://www.rosewill.com/media/downloadable/user_manuals/UserManual_HIVE_Series.pdf
You have to connect EPS cable. Your model comes as 4+4 connector.
PCIe connectors are different, as they are usually 6+2, or just 6. So no confusion here.
SasotoTopic starter
« Reply #4 on: 19-April-18, 15:40:07 »
YAYY THANK YOU!
I'll buy the cable and connect it now :3
Nichrome
« Reply #5 on: 19-April-18, 16:25:37 »
Buy the cable ?:confused2:
As far as I understand the manual, it's one of non-modular cables.
SasotoTopic starter
« Reply #6 on: 19-April-18, 17:29:47 »
Wait.. I think that's the one that the shapes didn't match with.
My cable has 4+4 on one end, and 8 pin on the other. Is this the correct one or am I missing one?
The only other cable that I can see fitting is one labeled PCI-E, which is 6+2 on one end and 8 pin on another. :/
SasotoTopic starter
« Reply #7 on: 19-April-18, 17:40:00 »
Here's the 4+4 cable:
https://imgur.com/gallery/sx6cURX
Here's the CPU PWR:
Here's the PSU:
https://imgur.com/gallery/fgyf13u
Unless I'm blind, Im pretty sure the 4+4 pin doesnt match any of the shapes, so I don't know if this is the right cable.
plutomate
  • MAJOR GENERAL
« Reply #8 on: 19-April-18, 20:54:42 »
that is the correct cable, just put it in and it's good to go
in case you're worrying
http://www.mycyonic.com/dev/wp-content/uploads/2015/11/06-CPU-300x180.png
gr33nbits
  • STAFF SERGEANT
« Reply #9 on: 19-April-18, 20:57:48 »
Btw the memory is on the wrong slots, you should use 1-3 or 2-4.
Ryzen 5 1600 @4.0 1.4v (H2O Cooled) | MSI B350 Gaming Plus 7A34vM7 | Gskill TridentZ 3200CL16 @3200mhz 1.35v | Gigabyte Aorus RX580 8gb | NZXT S340 (2x120mm Intake + 2x120mm Outake) | Corsair CX600 | SSD Evo 850 120gb + SSD Evo 850 250gb + 2x HDD 1Tb Western Digital Blue 7200rpm 64mb cache | LG 24MP68VQ-P ips@75hz Freesync + ASUS MG248Q tn@144hz Freesync | Gskill KM780RGB + Logitech 502 Proteus Spectrum @SteelSeries QCK+ | Logitech X-140 + Logitech G230
SasotoTopic starter
« Reply #10 on: 20-April-18, 01:07:00 »
Plugging it in, the Ez Debug still has the CPU led lit up. Does this mean my CPU is defected? :(
Also, I put the memory in the right slots :D
badboy2k
« Reply #11 on: 20-April-18, 01:17:25 »
what CPU cooler are you using?
also have you checked the CPU socket for any bent pins?
Cooler: corsair H100 cooler
SasotoTopic starter
« Reply #12 on: 20-April-18, 09:18:29 »
Here is my PC build:
https://pcpartpicker.com/list/Xwc2QV
Here is the CPU ( Thermal paste will be added once it is detected) :
https://imgur.com/gallery/rTWYPCy
I think a little rectangle piece fell off at the back of the CPU when looking at other CPU photos, but I'm not sure.
Here is the CPU socket:
https://imgur.com/gallery/XWrFtir
I matched up the arrow on the CPU to the mark on the socket too.
Nichrome
« Reply #13 on: 20-April-18, 10:07:53 »
Seems like couple of bent pins to me.
What do you mean you will add thermal paste once CPU is detected... :think:
SasotoTopic starter
« Reply #14 on: 20-April-18, 11:05:27 »
Wait so do I have to send back the CPU?
I would add thermal paste when  CPU isn't lit on the ez debug, because sometimes I accidentally touch it
Nichrome
« Reply #15 on: 20-April-18, 12:21:52 »
Bent pins occur on CPU socket itself (motherboard).
To me it sounds you might have burnt the CPU as well. Before any testing, thermal paste with cooler should be mounted.
badboy2k
« Reply #16 on: 20-April-18, 12:34:05 »
running a CPU without thermal Paste and a cooler is asking to kill the CPU!
never do that its a really bad idea!
SasotoTopic starter
« Reply #17 on: 20-April-18, 14:45:53 »
Oh.. I’ll see if I can fix the pins.
I’ll be sure to put the thermal paste and cooler too now! D;
I guess I’ll return the cpu and get a new one
SasotoTopic starter
« Reply #18 on: 06-May-18, 02:16:15 »
I was delivered a new CPU, I put thermal paste on it and the CPU cooler, but the ez debug still shows that the cpu isn’t detected :(
what do i do?
pls help
Nichrome
« Reply #19 on: 06-May-18, 16:42:51 »
RMA motherboard
