Author Topic: MSI Nightblade 3 VR Link (Oculus Rift)  (Read 830 times)
DOOMZLAIRTopic starter
« on: 22-April-18, 16:05:47 »
I have plugged in my Oculus Rift through the front of my computer (VR Link), and I plugged in the HDMI Cable Provided in the MSI Nightblade 3 box... My Oculus Rift is plugged in but won't display anything? :O How do I make it work? I plugged in the HDMI cable provided by MSI from the back that says HDMI in MSI's Red font colour and plugged that into the graphics card am I supposed to do that or not? I don't know sorry :(
Re: MSI Nightblade 3 VR Link (Oculus Rift)
« Reply #1 on: 22-April-18, 22:54:59 »
I have figured out that there was this VR Link in the back of the Computer just never seen it before but all I could do with my Oculus after putting it into the correct HDMI Slots was hear the Audio I couldn't get any Visuals in my Oculus Rift does anyone here know what I can do to get a Visual in my Oculus Rift?
  • Online Online
  • 微星科技
« Reply #2 on: 23-April-18, 11:56:56 »
Well, if you connect the hdmi-out on the rear with the hdmi-in on the rear the vr link hdmi-out on the front should be fine for audio and video. You can also simply try the hdmi out on the rear alone.
Core i7 7820X @ 4302.24 MHz (43 * 100.05 MHz, fixed all cores), 1.126v - delidded and using der8auer Skylake-X Direct Die Frame
MSI GeForce RTX 2080 GAMING X TRIO --> MSI GeForce GTX 1080 Ti GAMING 11G
Windows 10 Pro
MSI MAG BUNKER
