Author Topic: Afterburner showing zero degrees on GPU and 0% GPU load  (Read 1911 times)
ZPEROTopic starter
I have MSI Afterburner 4.5.0 and Rivatuner 7.1.0 installed. Windows 10 64-Bit, Ryzen 3 2200G (Adrenalin 18.5.1).
As you can see in the pictures, it is showing zero degrees for GPU temp and utilization, however GPU-Z has absolutely no issues at all detecting this very info.
What can I do?
  • 微星科技
Re: Afterburner showing zero degrees on GPU and 0% GPU load
« Reply #1 on: 25-June-18, 12:08:22 »
Afterburner is meant for discrete vgas not integrated gpus. If Ryzen G would be added it might take time. What mainboard are you using?
Windows 10 Pro
MSI MAG BUNKER Case
giuseppepennelli2005
  • CORPORAL
« Reply #2 on: 15-July-18, 10:01:48 »
if you need the app or try to format the computer or re-install the program
