Pages: 1 [2]  All   Go Down
Author Topic: Newest bios for nightblade mi2-020eu ?  (Read 8243 times)
Yang
  • AIO Moderator
Re: Newest bios for nightblade mi2-020eu ?
« Reply #50 on: 20-January-19, 19:34:03 »
Please run "commend prompt" as administrator in Windows 10 OS and input commend: update.bat.
karsten_h_94
« Reply #51 on: 25-January-19, 19:57:30 »
Is this something i should/could update as well?
System is:
Nightblade MI2C
MSB090G8S0104883
8.30
Yang
  • AIO Moderator
« Reply #52 on: 27-January-19, 19:14:10 »
Latest BIOS is v856.
Please check your mail one hour later.
karsten_h_94
« Reply #53 on: 28-January-19, 19:22:37 »
Thank you!
Do you know if this bios supports nvme ssds as a boot drive?
I am thinking about buying one, but have been seeing alot of stuff about bios needing to support it if i want to boot from it. Needs to be UEFI 2.3.1 or later?
Yang
  • AIO Moderator
« Reply #54 on: 29-January-19, 19:04:59 »
It is specification fro Nightblade MI2C on MSI website.
Support 1 x NVMe M.2 SSD (Combo SATA) + 2 x 3.5"+ 1 x 2.5"
https://www.msi.com/Desktop/Nightblade-MI2C/Specification
So NVMe M.2 SSD is boot drive.
kiba1212
  • CORPORAL
« Reply #55 on: 31-January-19, 01:25:25 »
Thanks a lot. You have been really helpful.
beeld
« Reply #56 on: 31-January-19, 09:08:43 »
good
beeld
« Reply #57 on: 31-January-19, 09:39:07 »
Hello I have an i7-7700k as well and cannot find the BIOS to get it to work.
S/N MSB090G1S0105477    motherboard is MS-B0901 ver:1.1,   the same as the Nightblade MI2.  my current Bios is EB090IMS.840 could someone help me get the Kaby Lake bios for this? please please
 Thank you in advance.
Yang
  • AIO Moderator
« Reply #58 on: 31-January-19, 19:05:42 »
This system is with full system that with Win10 OS for shipping.
If update BIOS to 7th GEN CPU, actived key of windows10 will be also removed.
You must be buy actived key of windows10 again from Microsoft.
beeld
« Reply #59 on: 01-February-19, 06:36:25 »
Mr. Yang but that is not bad if that has to buy then ,,
 I would like to have a bios for 7th gen ... My thanks is great Gr Beeld
Yang
  • AIO Moderator
« Reply #60 on: 02-February-19, 20:36:31 »
Again and Important!!
kristoferboden
« Reply #61 on: 03-April-19, 14:52:02 »
Hi, is there anybody who can send me the latest bios for this?
I would be very thankful.
Yang
  • AIO Moderator
« Reply #62 on: 08-April-19, 00:13:59 »
Please provide some information as below to us for this system you used:
1. Serial number on the back cover and on the box.
It is SOP how to check it as below link:
http://www.msi.com/page/warranty
2. The number:9S6-xxxx-xxx that you can find it on the box.
3.Please provide BIOS version.
matthias.perrot
« Reply #63 on: 02-May-19, 13:30:28 »
Is this something i should/could update as well to run i7 7700 on that computer? Understood about windows license.
System is:
Nightblade MI2C-044fr
MSB090G1S0104942
8.30
Yang
  • AIO Moderator
« Reply #64 on: 02-May-19, 20:20:12 »
matthias.perrot
MSB090G1S0104942 is with OS for shipping.
If you flash BIOS to support I7-7700, will be lost actived key of OS and must be buy it again from Microsoft.
So not suggest flashing BIOS for support I7-7700.
matthias.perrot
« Reply #65 on: 02-May-19, 23:53:37 »
You mean i7 7700 will be supported without bios flash? I understand and accept buying new windows license to support hardware upgrade.
Yang
  • AIO Moderator
« Reply #66 on: 03-May-19, 00:12:24 »
Must be flash BIOS first and then will be support I7-7700.
matthias.perrot
« Reply #67 on: 03-May-19, 00:44:57 »
Ok then how to get the new bios?
Yang
  • AIO Moderator
Please check your mail.
matthias.perrot
« Reply #69 on: 04-May-19, 14:39:50 »
Got the message thank you.
Originally I was 840 and not 830.
Followed the flash8m from the 510 and it said something like
Warning: The file does not contain enough data to completely fill the target write area! Continuing will truncate the Write Lenght to the File Length!
File: 'EB090IMS.510"
File Length: 4190208
Write Length: 7335936
Want to coninue? Y/(N) or q to quit
I did yes, it rebooted but then bios stayed 840.
Then I did the ME thing and it goes ok.
Switched the new cpu, but nothing.
Switch cpu back, flashed 856 then 855 then back to 840, bot none of all those worked with 7700.
Is it possible ram 8g 2133 does not work with new cpu?
Tried the 510 again and now it says error d4 and something about memory size mismatch.
Never been able to see 510 in the bios setting.
matthias.perrot
« Reply #70 on: 05-May-19, 04:11:23 »
Exact error is d4 error : the system d’ami data site is greater than rom file’s dim data length
Without /r it says :
18 secure flash rom verify fail
Is it the good rom file?
matthias.perrot
« Reply #71 on: 05-May-19, 05:25:32 »
Finally, a reboot booted me in the 510 bios, and 7700 is working fine! Thanks!
support
« Reply #72 on: 16-May-19, 08:41:40 »
Hi
I have Nightblade MI2c-221XPL
I need new bios for this computer.
Number: 9S6-B09021-221
Serial number MSB090GAS0120340
My old chip is damaged. Is it possible to send in *.bin format?
My chip is Winbond W25Q80BVSIG
Thanks
Yang
  • AIO Moderator
« Reply #73 on: 17-May-19, 00:22:56 »
support
jakeyizafunn.js
« Reply #74 on: 21-May-19, 17:45:33 »
looking for the new bios since you guys don't wanna post it
Nightblade MI2-001BUS-BSX   serial number - MSB090GAS0102931      im on bios version 840 currently
Yang
  • AIO Moderator
« Reply #75 on: 21-May-19, 20:14:43 »
jakeyizafunn.js
eivind-br
« Reply #76 on: 11-June-19, 13:27:47 »
Mr Yang
Can you please help me get the latest BIOS.
MSI Nightblade MI2C - 203EU - B5640010668G1T0S10M
S/N: MSB090G8S0104634
9S6-B09021-203
MDL:MS-B09021-01S
Intel Core i5 - 6400, 2,7 GHz
GTX 1060 Armor, DDR5 6GB
BIOS Ver: EB090IMS.840
Thank you!
Yang
  • AIO Moderator
« Reply #77 on: 11-June-19, 20:14:32 »
eivind-br
Please check your E-mail.
corylowe21
« Reply #78 on: 04-July-19, 22:53:38 »
link=topic=305289.msg1818003#msg1818003 date=1556862297]
[/quote]
corylowe21
« Reply #79 on: 06-July-19, 14:21:01 »
Is there a new bios for my
Nightblade Mi2-001BUS-BSX
S/N MSB090G7S0102470
Can someone please help me with this bios update?
Yang
  • AIO Moderator
« Reply #80 on: 07-July-19, 20:54:48 »
corylowe21
f.goe
« Reply #81 on: 11-July-19, 08:06:40 »
Please is there a new Bios for my Nightblade MI2-002DE
S/N: MSB090FAS0103379
Now I have Bios 830.
Many Thanks
Franz
Yang
  • AIO Moderator
« Reply #82 on: 11-July-19, 20:03:50 »
f.goe
f.goe
« Reply #83 on: 12-July-19, 12:28:47 »
Yang
Thank you, everything is fine.
Regards
atakanak85
Re: Newest bios for nightblade mi2-051tr ?
« Reply #84 on: 27-July-19, 14:10:48 »
The newest bios for mi2-051tr on the product page is 830. Is there a newer bios for this system ?
https://www.msi.com/Desktop/support/Nightblade-MI2
Thank you.
Yang
  • AIO Moderator
« Reply #85 on: 28-July-19, 20:05:13 »
atakanak85
dennisvdweg
« Reply #86 on: 30-July-19, 04:24:37 »
Hi Yang
Do you have a bios update for me? I have 840 from 2016.
Micro-Star International Co., Ltd. MS-B09012
System Manufacturer
System Model
MS-B09012
System Type
Desktop
Motherboard Manufacturer
Motherboard Product
MS-B090
BIOS Version
8.40
SMBIOS Version
3.0
Secure Boot
On
Yang
  • AIO Moderator
« Reply #87 on: 30-July-19, 20:08:34 »
dennisvdweg
zachderickson
« Reply #88 on: 05-August-19, 09:40:02 »
I need to update my BIOS to run an I7 processor with my Nightblade MI2, the S/N is MSB090G7S0102525
Yang
  • AIO Moderator
« Reply #89 on: 05-August-19, 20:01:18 »
You can be run I7 process on this system.
It is specification for Nightblade-MI2 on MSI website.
6th Generation Intel® Core™ Processors
https://www.msi.com/Barebone/Nightblade-MI2-Barebone/Specification
zachderickson
« Reply #90 on: 07-August-19, 16:30:48 »
Mr. Yang, the computer doesn't POST with the I7 in it, and other people in this thread have had this issue fixed by updating their BIOS. Why isn't this the same?
Yang
  • AIO Moderator
Example: MSB090xxxxxxxxxx
2. The number:9S6-B090xx-xxx that you can find it on the box.
Don't post the same question again.
zachderickson
« Reply #92 on: 13-August-19, 13:42:13 »
Mr. Yang.
the Serial number is: MSB090G7S0102525. Thank you!
The other number: 936-B09011-001
Yang
  • AIO Moderator
« Reply #93 on: 13-August-19, 19:58:06 »
zachderickson
ahwuilove
« Reply #94 on: 14-August-19, 19:06:46 »
Hi I'm also looking for the new BIOS update for my MI2-069XTM
Serial Number: HSB090G4S0102939
Thanks a lot.
BIOS Ver: EB090IMS.830
BIOS Build Date: 01/11/2016
Yang
  • AIO Moderator
« Reply #95 on: 14-August-19, 20:03:01 »
ahwuilove
tosarkki
« Reply #96 on: 22-August-19, 09:39:20 »
Can I have the latest bios to support i7-7700 please.
MSI nightblade MI2C-095EU-B5640010668G25S10M
S/N:MSB090G8S0102812
onitakarus
« Reply #97 on: 03-September-19, 16:18:19 »
Hello, I have Aegis 001BUS-BSX
I really need to install kaby lake, my s/n: MSB901G3S0102347
I want the appropriate bios > 510?
p.s.
500 showed an error d4
Yang
  • AIO Moderator
« Reply #98 on: 03-September-19, 20:05:17 »
onitakarus
Pleaes open new topic.
This system is Aegis at your side.
This topic is for Nighrblade MI2C.
Both are different model.
tu_m
« Reply #99 on: 05-September-19, 07:21:44 »
Hello,my system is Nightblade MI2,S/N:MSB090F8S0102701,i want to get 7th core support,thanks a lot!
Pages: 1 [2]  All   Go Up
