Author Topic: [REQUEST] Latest BIOS for GTX 1060 GAMING X 6G  (Read 415 times)
arthur.lolicoTopic starter
Good afternoon. I would like to know if I have the latest BIOS for the 1060 Gaming X 6G.
S/N: 602-V328-010B1701000471
Thanks. :D
  • 微星科技
Re: [REQUEST] Latest BIOS for GTX 1060 GAMING X 6G
« Reply #1 on: 12-July-18, 15:09:16 »
You are using vbios NV328MH.122. Latest is NV328MH.123: https://forum-en.msi.com/index.php?topic=295756.msg1667819#msg1667819
Windows 10 Pro
MSI MAG BUNKER Case
« Reply #2 on: 12-July-18, 17:10:49 »
Thanks, flobelix. Any noticeable differences between these BIOS?
  • 微星科技
« Reply #3 on: 13-July-18, 10:50:08 »
No idea, you will have to try or not update if you don't have any problems. Changelogs for vbios aren't public.
Windows 10 Pro
MSI MAG BUNKER Case
