Author Topic: Request Latest-Correct Bios for MSI GTX 1070 Gaming X  (Read 1795 times)
patrik83Topic starter
Hello,i install the current bios from techpowerup
Product Name: MSI GTX 1070 Gaming X
S/N:602-V330-43SB1607037879
My current bios is 86.04.50.002A(wrong one?)
  • 微星科技
Re: Request Latest-Correct Bios for MSI GTX 1070 Gaming X
« Reply #1 on: 14-July-18, 05:12:44 »
Never do that, you can't tell if a vbios matches your card or is even later than what you have. There are many different vbios series even for the same model depending on the batch of card.
No, that is not your vbios version. It is just a nvidia refrence part of vbios. The version is actually NV330MH.241. Luckily that one is correct for your card with S/N 602-V330-43S. There is an update though. latest is NV330MH.242: https://forum-en.msi.com/index.php?topic=302551.msg1755476#msg1755476
AMD Ryzen 9 3900X
Windows 10 Pro
« Reply #2 on: 14-July-18, 09:15:41 »
Yes..MSI remove the bios section from the card webpage and i didnt know that different batch need different bios.
Thanks for informing me and thanks for your support.
My Kind Regards.
  • 微星科技
« Reply #3 on: 14-July-18, 09:17:33 »
:hat tip:
AMD Ryzen 9 3900X
Windows 10 Pro
