Author Topic: MSI DS502, broken..?  (Read 815 times)
dolerayuroTopic starter
« on: 23-July-18, 06:02:05 »
Hello.
I googled the problem for my headphones but no luck... so I decided to create an account here. Anyway, let's get to the point.
I bought my headphones at 2017 Summer, and it was doing great until last week. Bass isn't properly working anymore, I'm hearing weird noises from the left speaker, and I think cables are heating a lot (Even though my computer is cool and my desk is making me freeze).
What is causing the problem? Is my headphone broken?
carsfanatics23
Re: MSI DS502, broken..?
« Reply #1 on: 05-September-18, 05:22:24 »
Hhm definitely seems like ur headphones are broken. If its still under warranty contact MSI and they will replace ur product for you!
gerritsen.wouter
« Reply #2 on: 07-October-18, 13:52:45 »
I got the same problem! Vibration motor doesn't do anything anymore, cables are getting really hot and there is a sound volume difference between left and right... if someone knows a solution, please help!
