Author Topic: WS63 Dual Display with CalDigit TS3+  (Read 421 times)
tuggerTopic starter
« on: 01-August-18, 10:02:07 »
I am trying to get my WS63-8SL to play nice with a CalDigit TS3+ docking station.
I have 2 Dell P2214H monitors which have the following ports: DVI-D, VGA, DisplayPort.
On the TS3+ there is a DisplayPort and a TB for the monitor outputs.  I have the following to connections:
Monitor 1 -TB to DP
Monitor 2 - DP to DP
If both are plugged in, only Monitor 2 works
Monitor 1 only plugged in, Monitor 1 works (unless I plug Monitor 2 back in, which makes Monitor 1 go black)
Monitor 2 only plugged in, Monitor 2 works (if I plug Monitor 1 back in, nothing happens other than the tone for a new connection)
I have even tried plugging Monitor 1 directly into the WS via DP to HDMI and DP to mDP cables.  In both cases Monitor 1 remains black.
In all cases where both are plugged in, if I go into graphics properties (with Windows or Intel) and use the detect button it states that no other monitors are detected (Monitor 1 is always black)
Anyone else have experience with this and found a suitable solution or workaround?
